Trying to understand Decel enleanment in $58:
Car: 1990 Formula
Transmission: WC T5
What I am trying to figure out is how to determine from a log if I am entering DE: (From what I am seeing I believe most of the time in DE I am going rich)
And How long am I in DE (how many scan entries)
From the info I have:
DETHROT component of DE is used if the rate of change (decreasing) is greater then a threshold.
I am not real clear on the threshold info:
THRESHOLD = Filtered throttle position if *KAFOPT3*, bit 4 = I = 12.5 mSec old throttle position if *KAFOPT3*, bit 4 = 0.
Then it is based on this formula:
DETHROT = *F36*( (THRESHOLD-TPS )*8)
Table F36 is:
0x04FB F36_TABLE DE Throttle Contribution vs Throttle Change
% 0 6.25 12.5 18.75 25
(%) 7.4 11.3 20.7 20.7 20.7
For map it is based on manifold pressure term where if it changes by a factor greater than KDEPMTH (Which is 1.9 KPA in my bin) is uses the table F35
0x04F5 F35_TABLE DE MAP Contribution vs MAP Change Above Thresh.
% 0 10 20 30 40
(%) 3.1 6.6 12.5 28.9 28.9
If looking at part of a scan, is this in DE? From the scan, how can I determine which of each factor is contributing to the DE. (I know that these two factors are added together and multipled by two other factors to get total DE, but I would like to know how to figure I am in DE so I can make educated changes to the DE terms)
Here is one where I go rich
Here is one where its lean
Table F36 is:
% 0 10 20 30 40
Code:
TPS % RPM RunTm KPA AFR 9 2175 79 35.34 14.7 9 2125 79 35.34 14.7 9 2125 79 35.34 14.7 9 2125 79 35.34 14.4 9 2150 79 35.34 14.7 8 2125 79 35.34 14.7 8 2125 79 34.55 14.4 8 2125 80 34.55 14.7 8 2100 80 33.77 14.4 8 2100 80 32.99 14.2 7 2150 80 31.43 14.1 4 2150 80 27.53 14 2 2100 80 24.4 13.3 2 2150 80 22.06 13.1 1 2100 80 20.5 13.2 0 2150 80 20.5 13.8 0 2100 81 18.93 14.1 0 2100 81 18.93 14.4 0 2075 81 18.93 14.7
Code:
TPS % RPM RunTm KPA AFR 25 4350 196 44.71 14.9 25 4350 196 43.93 14.9 24 4375 197 42.36 14.7 18 4375 197 34.55 15.5 3 4225 197 17.37 16.5 0 4025 197 14.25 17.9 0 3775 197 14.25 17.9
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
That's probably decel enlean (but at low MAPs, it's hard to tell what causes the A/F seen, because it's so dependant on so many things), but it becomes much more clear when you go from 80+ to <50 kPa. If decel enlean is disabled there, you'll see it reach 12's likely. If it's too much, you can feel the engine almost cutout and then comeback. Too much will cause a buck when lifting throttle (but not completely to 0), too little may be un-noticable, maybe will backfire out the exhaust if it's worst case and cutoff is entered.
Car: 1990 Formula
Transmission: WC T5
As a note, I do have DFCO disabled.
One of the items that I am trying to get at is, In say the top log, I should be in DE because of the dropping tp%. How do I determine which cell in F36 I am using at a specific time and each log reading is how far apart?
So say these three entries from above:
is there enough tp% change for DE?
If so is it using the 0% value of 7.4 for the tp enleanment term?
or is there not enough tp% over this given time in the log to enter the tp part of de.
Code:
