Prom upgrade if I go from 350 to 383?
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi...
Do I need to upgrade my PROM if I go from 350 to 383. All the other thing will be the same, cam, heads .........If so it's cheaper to buy a accel/unit and make it to a speed density than paying for another custom burned chip from TPiS
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Car: An Ol Buick
Engine: Vsick
Originally posted by gta324:
Hi...
Hi...
Then for $200 you can do you own proms and have all sorts of fun.
Grumpy http://www.gnttype.org/carofthemonth...omdetails.html
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
TPIS offers reburns/trade ins for I believe $85 - 95. I don't think you will need to change your prom if all you are doing is changing the stroke. Are you keeping the rest of the setup the same?
Sparks a flyin'.
1989 L98 IROCZ, Bored .030 over,400 Crank,Dart PRO 1 Heads 200cc intake,ZZ3/ZZ4 Cam,Crane 1.6 RR,Edelbrock 3860 Hiflo TPI Manifold, AS&M LTRs, Edelbrock 58MM TB, Ported Plenum, TCI Reverse Pat Man Valve Body, SVO 24# injectors,TCI Streetfight Stall Converter, 3.23 Gears on Auburn Pro Posi, Some Suspension Mods
[This message has been edited by sparks383iroc (edited November 27, 2000).]
Sparks a flyin'.
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
TPiS requires that you buy a new level V prom if you change the engine size. I'm planning to have the rest of the set up, only port the heads.....
Maybe I'll go for a 9 psi ATI later.....
Hey-Sparks...How does you engine perform? with a 383 and LTR, do you have any dyno results?
If you have the money go with dfi. There are no chips to pull out and burn and you dont have to buy a scan tool. (all of that is fine if you enjoy it) But with dfi you can tune on the fly and record data all through your laptop.
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.
Car: An Ol Buick
Engine: Vsick
The oem ecms have alot more going for them, and you'll notice over the years the aftermarket ones are getting alot more like the oem ones for tables and tunablility. For the difference in any price I can sure buy alot of proms.
Other thing is that for most folks on-the-fly is worse then chip burning!. Why?, cause fewer notes are takin, and hence possible trends to wha the engine actually likes can be missed.
Plus you can improve the prom stuff in stages.
A diacom is very universal program, and hense you can use it on alot of different vehicles. (BTW, while it takes some effort, there is alot of diacom info readily available)
Eric-86sc
Aug 24, 2015 09:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
Sanjay
Aug 12, 2015 03:41 PM
