Hey grumpy???
Old Nov 27, 2000 | 11:58 PM
87Z-ya's Avatar
Hey grumpy???
Is that a lt1 maf on your car? Was just curious on how it works if you are still running the original t type computer
Old Nov 28, 2000 | 10:15 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Yes, it is.
My GN is electrically enhanced <g>
Modern Musclecar sells what is called a translator and then a translator plus. Both of these allow you to run the late MAF with the oem ecm (1227148 specific so far). I can from the drivers seat add or subtract fuel at WOT, and make universal timing changes, and ramp timing in or out starting at 3,200 rpm.
I also have a devise where I can change timing as a function of boost using a MAP sensor, *thru* the MAT sensor.
also, have a new devise to allow me to switch between 16 bins also from the drivers seat. I haven't installed that yet, still sittin in the living room.
Also, have a switch for clearing the memory from inside.
It is truely electronically tunable from the drivers seat <g>. Specially with the WB O2 and Direct scan humming along.
Direct scan does a HP and torque calculation based on some entries, so that I don't need to run other then tru one gear to note any trend
Old Nov 28, 2000 | 11:14 PM
87Z-ya's Avatar
Sounds very trick, and also like alot of time involved. Nice car. I guess the translator converts the digital reading of the maf to analog so the gn computer can read it? Have you ever seen this done on a 165 ecm?
Never mind that I saw you said it was specific to your ecm.
[This message has been edited by 87Z-ya (edited November 28, 2000).]
Old Nov 29, 2000 | 12:07 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Grumpy,
I inslalled a MAF translator on my '99 SS.
Does Modern MuscleCar market one for 3rd gen TPI cars?
Is this a suitable method for me to get more fuel during WOT runs as opposed to burning my own prom chips?
Please review the comments that I made on the TPI section concerning O2 readings & tuning.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(48psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter.
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
next mod: 4.10 rear gears
Old Dec 1, 2000 | 01:41 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Originally posted by doc:
Grumpy,
I not familiar with what our talking about on the 99SS. So I can't coment on it. In general the 96+ cars are really well calibrated compared to the earlier stuff.
I've donated a 165 MAF to Bailey Eng., designers of the Translator in an effort to get a version for the 165 guys. But, they are busy with current stuff, hopefully things will slow enough for it to happen. It might go some distance if someone wanted to get a *group* buy together and guaranteed an initial buy of x amount. I'm not connected with either, and this is just something off of the top of my head.
Old Dec 1, 2000 | 01:26 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
they both are frequency (ie digitial), the oem one is 30-130 Hz, and the late models are in Khz Late ones can have greater resolution then the earlier ones.
Loudnproud86
Jul 14, 2016 12:59 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
Zane Story
Oct 8, 2015 12:40 PM
chuck13
Interior Parts Wanted
Sep 22, 2015 11:19 AM
Keiffer76
Sep 9, 2015 08:52 PM
