i'm lost, replaced ecm and the vats keeps setting
Old Dec 9, 2000 | 12:30 AM
UnderDogRS's Avatar
i replaced the ecm this week w/ a 7747.
but at the track tonight the vats set 2 times.luckly i was in the lines and not up front. i thought when i replaced the ecm
the speed limiter and vats were disabled.
so what do i do?
tia,
RS
1992 Camaro RS
Mods:
14x3 Open element w/ K&N filter, MSD 6a, MSD GM blaster Coil ,MSD 8.5 SC wires, AFPR,Fuel Pressure gauge(60Psi max), 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
Best Time: 15.279@89.02MPH
Underdog Racing
Old Dec 9, 2000 | 03:41 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
so what do i do?
tia,
RS
First would be explaining what is going on, since I have yet to see a 1227747 with VATS.
Old Dec 9, 2000 | 06:45 PM
Brent's Avatar
Grumpy is correct, the 7747 doesn't require the vats signal.
Disabling VATS in the prom DOES NOT disable the rest of the VATS system which is separate from the ECM.
Your problem with no crank at the track is a VATS system problem. Not ECM.
Old Dec 10, 2000 | 01:19 PM
UnderDogRS's Avatar
sorry i guess thats what i was asking. if it was the ecm or something else. So how do i disable the vats system. is there a relay
or a bypass i have to do. its scary to be someplace you might have to leave in a hurry,
and woundering if your car will start.
tia,
RS
1992 Camaro RS
Mods:
Underdog Racing
specialized
Jun 18, 2022 09:26 AM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
marcusaw
Aug 10, 2015 08:13 AM
djmarch
Aug 9, 2015 05:27 PM
