Help, where do i find out what EPROM?
Old Dec 10, 2000 | 06:04 PM
leirch's Avatar
I have an 87IROC as you can see in the sig, how do i go about finding which eprom i need to start writing my chips? I have all of the other info(writer, eraser and software). I just don't understand what i'm looking for on the suggested chip sites that Tim suggested in his "learning to program 101".
He gave a couple of companies webpages that sells them but i don't have the slightest idea to which chip i need.
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Chrome Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
Old Dec 11, 2000 | 12:36 PM
UnderDogRS's Avatar
http://www.diy-efi.org/gmecm/ecm_info/1227165/
and...
https://www.thirdgen.org/newdesign/tech/promintro.shtml
you have the 1227165. those 2 sites should help get you started. some of the others on the board will be able to help you more. im still learnign myself.
you need a BIN file for your setup.and the software to edit the bin. the first link should be all you really need now.
HTH,
RS
1992 Camaro RS
Mods:
14x3 Open element w/ K&N filter, MSD 6a, MSD GM blaster Coil ,MSD 8.5 SC wires, AFPR,Fuel Pressure gauge(60Psi max), 3-Row Al rad. , 180* t-stat, Hooker 1 5/8 headers, 3" Catco cat, 3" Hooker Aero Chamber cat-back, "Ultimate TBI" mods
Best Time: 15.279@89.02MPH
Underdog Racing
[This message has been edited by UnderDogRS (edited December 11, 2000).]
Old Dec 11, 2000 | 12:43 PM
leirch's Avatar
I know what software and bin i need. I just don't know which psychical BLANK EPROM chip i need to buy.... Like on the webpage tutorial that Trax made he gives a couple sites that sell all kinds of different eproms but i don't have the slightest idea to which one i need....
Old Dec 11, 2000 | 02:57 PM
InTech's Avatar
Your computer should have a 27c128 chip....on very rare occasions GM used a 27c256 chip(although I have never personally seen it) If so, I have been told you write the same .bin to the upper and lower addresses. hth's....btw if it is a 27c256 you will get differing checksums every time you read it.
-Carl
Old Dec 11, 2000 | 03:09 PM
leirch's Avatar
Ok, guys, thanks for the replies, i'm retarded. I guess if i would have read Trax's page a little closer i would have found the info myself.
Brendan
ChristinaMarie
Sep 11, 2015 06:28 PM
NiG
Sep 7, 2015 11:25 PM
