'91 Vette L98/6-speed Chip??
Old Dec 26, 2000 | 12:54 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Did they make a '91 vette 350 stickshift chip? Is it a Speed Density setup? Would this work in my '91 GTA that will have a 350SD TPI and 5-spd? I am not interested in buring my own at this time, but will probably do so in the future. Thanks for any help! The only reason I'm doing so is because someone said that they are only like $30-$40 at a dealer. THX again
'91 GTA:5.0TPI-5-spd, Hypertech Stage 2 chip, 160stat,!TB,!Cat, K&N, Flowmaster muffler, Accel Coil,TPI Air Foil, 1LE Alum DS, poly-tranny mount, KYB's all around, & a Hotchkis Strut tower brace.
Mods in progress:
-L98 w/ZZ4 cam/springs
-Edelbrock headers
-3" flow setup
Future:
-T56/heavier clutch
-Hurst or Ripper
-4.10's
-Ram Air II Hood
-1.5" Springs
-Rebuild suspension!
Others:
-39 Chevy coupe
350/350/3.55posi
-52 Chevy p/u
-77 Bonneville 400PONTIAC/400turbo/posi
Original 50k mile 2 door... Gramp's old car!
*** Gotta love those Poncho's***
Old Dec 26, 2000 | 04:39 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep they sure did. I used one in mine for a while, but I kept getting a code 52, for no oil temp sensor. I replaced it with a 305 5-speed f-body chip.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 26, 2000 | 06:04 PM
Ricky Bettinger's Avatar
Kevin will the 91 vette chip have the reverse block out?
Old Dec 26, 2000 | 11:10 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Do we have an oil temp sensor? If not, then it wouldn't matter using it would it? Or did it set off the check engine light? So Kevin you are running a stock 5-spd chip then right? Any mods to make it work or just swap motors out and go with it? THX!!!
Old Dec 27, 2000 | 01:34 AM
Kevin91Z's Avatar
What is a reverse block out?
And yes, I would get an SES light every time I drove on the freeway. Code 52, like I said. I was using a stock 305 5-speed chip, but right now I am using a 350 automatic chip. The 305 chip worked fine with my ZZ4 cam and heads. I then took it over to Turbo City and had Tom there modify it to give it more timing at WOT so I wouldnt have to bump up my initial timing so much. When I put in the LT4 HOT cam, I'm gonna have to do some dyno tuning to compensate for the larger cam. I dont think the stock chip will handle that cam like it did with the ZZ4 cam.
Old Dec 27, 2000 | 07:53 AM
[QUOTE]Originally posted by Kevin91Z:
[B]What is a reverse block out?
Kevin I am installing a ZZ4 and a 6-speed into a 91 camaro that had a 5-speed. The 6-speed has a reverse block out actuator that blocks access to reverse when forward speed is 5 mph or more. Can I use the vette chip?
Old Dec 27, 2000 | 12:12 PM
Kevin91Z's Avatar
Oh, on a T56? Yes you can use the chip, because our computer doesnt control the T56. You will need some kind of push-button switch to activate the solenoid. Or, I've heard some people say they can get it into reverse without the solenoid.
Old Dec 27, 2000 | 03:01 PM
Kevin with this vette chip can I wire it in just like a 6-speed vette with out the button?
Thanks for your time.
Old Dec 27, 2000 | 06:02 PM
Kevin91Z's Avatar
I dont know, I havent installed a T56. Post this question on the Trans forum and maybe someone who has knowledge will answer.
Old Dec 27, 2000 | 09:58 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
KEVIN-
How do you like that 350 auto chip? Could I run a 160 stat w/ a 350 auto STOCK chip?
RICK-
A lot of guys wire the reverse lockout to the brake pedal light switch. This way it can only be put in reverse when the brake is applied. Just a thought! Later
Old Dec 28, 2000 | 12:09 AM
Kevin91Z's Avatar
I'm running a 160º thermostat right now. My 305 chip had the primary fan turn on temp at 185º but I'm still running about 180º temp according to Diacom. I've tried both the 305 5-speed chip and the 350 automatic chip and I see very little difference on a WOT run.
Old Dec 28, 2000 | 04:12 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Cool man, thanks. I guess I'll stick with my Hypertech Stage 2 with a 160 stat. They were int he car when I bought it so they were free anyways! Ya think I should keep them? I don't think that my 2nd fan ever kicks in though???
Old Dec 28, 2000 | 06:00 PM
Kevin91Z's Avatar
Nope, the secondary fan is designed to come on around 226º, I think... You can get a hypertech fan switch to make it come on at 185º, or one from Turbo City (I got this one) or you can get one from GM for a Turbo Buick Regal or Grand National that comes on at 201º or so. The GM one is cheaper, I believe, but I dont have a part number for it, sorry.
Old Dec 28, 2000 | 06:56 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
On the 730 ecm, you can alter the temperature that your second fan turns on and off if you burn your own PROM. I prefer this method as if you should change to a different T-stat temperature, you just have to alter the PROM and reburn it. With the fan switch, you would physically have to change it again.
Another cost savings reason to look into burning your own PROM.
Old Jan 4, 2001 | 04:15 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
I tried using a friends 90 L-98 ZF-6 chip in my car about a couple of years ago, and it WOULD NOT START THE CAR....PERIOD. I think that it was because I didn't have PASS key or VATS.
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Old Jan 4, 2001 | 04:28 PM
BOWTYE8's Avatar
Hi
I am running a 7730 in my 85 vette. My 85 vette has a oil temp sensor as well and I still get teh code. My ser lite comes on after a long highway drive as well but I feel this is due to just that low oil temp. I run a 160 stat and my fan go on at 180. Not shure whatthe critiria is for the low oil temp service lite enable. maybe in the manual.
I dont have a 90-91 manual so if someone does know the low temp enable TEMP feel free to post. I shure it can be changed via a hex editor.
85 vette,383,miniram,ZF6,4.10's..best ET 11.66@1187.00 60' 1.62
w/100HP nirous 11.05@127
http://geocities.com/bowtie8
Old Jan 4, 2001 | 07:19 PM
Kevin91Z's Avatar
Yep, thats why. The 90 chip looks for VATS, which your 88 doesnt have. So it wont start. You'd need an 88 chip. Or 87, did VATS start in 88 on Corvettes and 89 on F-Bodies?
Old Jan 4, 2001 | 08:11 PM
Car: Death Mobile
Engine: 666 c.i.
I have a simple solution! Just grab an AUJP bin (that's the SD L98 F-body auto without the oil temp sensor) and change the transmission parameter in the Constant Switches from Auto to Manual?
I was curious if Tuner Cat would do it, so I tried modifying my AUJP bin. When I looked at the actual code, it properly switched the code. So go get yourself a PROM burner.
Old Jan 4, 2001 | 11:46 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
glenn, theres alot more to it than that the IAC function is way different for a manual car than an auto, when i ran the auto chip in my car with the manual i had real bad low speed surging amongst other things
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
FormulasOnly
Jul 23, 2018 08:47 AM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
