Can I make ECM 1227165 with PROM 8958AMU work?
Old Jan 10, 2001 | 04:39 PM
87/88Firetruck's Avatar
I am having a heck of a time finding one ECM in the entire Houston area which matches the numbers specified for vehicles using my engine. I have located ECM 1227165 with PROM 8959AMU from a 1986 305 Camaro, and am wondering if this will work with my setup. I am using a 1987 350 L98 MAF system with all stock wiring for a 1987 model vehicle. Can I simply connect the harnesses to this ECM and go? Since many people convert 305 systems to work on a 350 by simply changing the injectors from 18 lb/hr to 21 lb/hr, it would seem that swapping to a 305 ECM on a 350 system would have the same effect. I would appreciate any information of suggestions. Thanks.
Old Jan 11, 2001 | 01:02 AM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Check under Engine/Induction/Exhaust in the following link. www.thirdgen.org/newdesign/faq/thirdgen.shtml
86 IROC T5
MSD 6A
Summit cam
Flowmaster
AFPR
Lowered 1.5"
My own prom (finally)
Old Jan 11, 2001 | 06:05 PM
tpic1500's Avatar
Good luck on the swap. I converted my 1989 C1500 from TBI to TPI. I am using a 7730 ecm so I had to rework the harness. The 165 is the way to go, it is almost identical to the 7747 on the pim configuration. If you need any pin info., go to DIY-EFI INCOMING , it ha a lot of info. from a-z. If you need front engine brackets, you can get them from a '88-'92 camaro or firebird v-8, doesn't matter if it is tbi or tpi. Good luck!
Nick
Steven 86IROC-Z
May 24, 2026 04:52 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
djmarch
Aug 11, 2015 10:22 AM
djmarch
Aug 10, 2015 08:42 AM
marcusaw
Aug 10, 2015 08:13 AM
