Maf sensor use
Old Jun 28, 2006 | 01:32 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Maf sensor use
Has anyone ever thought of using a maf sensor as a flow bench sensor to record flow data on a laptop? I may be way off the deepend on this but I would think it could be done with the proper calibration using a manometer. I figure the orifice for the maf flows plenty of cfm for a cylinder head bench.
Old Jun 28, 2006 | 01:41 PM
HaulnA$$'s Avatar
Originally Posted by shaggy56
Has anyone ever thought of using a maf sensor as a flow bench sensor to record flow data on a laptop? I may be way off the deepend on this but I would think it could be done with the proper calabration using a manometer. I figure the orifice for the maf flows plenty of cfm for a cylinder head bench.
Why use a manometer to calibrate the MAF? Why not just use an ECM that is already calibrated for that particular MAF? You already have a ready made output with the ALDL datastream which can then be exported to Excel and charted. Just a thought.
Old Jun 28, 2006 | 01:54 PM
shaggy56's Avatar
Car: 71 Nova
That was a thought as well. Im seeing it requires lots of calculations.
http://www.engr.mun.ca/~abdi/Fluids4...uidsI_lab2.pdf
Old Jun 28, 2006 | 08:16 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Yep.
Gonna use a Ford MAF thou. Reading a straight voltage rather then the new GM signals is easier, IMO.
And it'll make for a neat way to actually check if a VE table is close to being correct.
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
Racerx974
Sep 19, 2015 10:16 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
