I need a starting point.
Old Jan 22, 2001 | 11:42 PM
GTARob's Avatar
I am getting ready to put in the new 383. I am going to be using my car to learn about prom burning but, I need a starting point. I need to find out where to set everything too get my engine running reliably. Here are the engine specs.
383 stroker 350 with 400 crank 10.5/1 compression.
30lbs per hour injectors
adj. fpr.
walbro 255lph fuel pump
52mm throttle body.
World products 64cc comb. chambers
2.02 intake & 1.66 exhaust.
1.6/1 roller rockers
Stock TPI intake. ( it has been ported and polished)
The cam is a custom ground Lunati.
lift - int.452 exh.465
dur. @ .050 - int.214 exh.220
lobe separation 112 degrees
valve timing int. open@ 0 closed @ 47
exh. open@ 34 closed @ -7
Edelbrock TES headers. 1 5/8 inch primaries.
I am keeping all of the emissions in place. I just need to get everything set so that I can drive the car while I learn.
GTAROB
1989 GTA TRANS AM
305 TPI, 5 SPD
SWAPPING TO TPI 350 NEXT MONTH.
Old Jan 23, 2001 | 12:43 PM
GTARob's Avatar
Come on. Throw me a figgen bone here.
1989 GTA TRANS AM
305 TPI, 5 SPD
Old Jan 23, 2001 | 03:00 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Rob,
We already talked via e-mail but I'll post here also.
Basically, you have a 305-383 swap. Here is what you want to do....
Get a chip from a 1989 Corvette with manual transmission. Change the bin via a program like TunerCat to use 30lb/hr injectors. That's it. That is your starting point.
After you get it running you will probably want to dive into the MAF tables and the WOT PE vs. RPM table. But, that is AFTER you get it running.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
