using winbin to change injector size?
I have a 91 Z28 that I swapped in 22lb injectors. My question is using winbin should I only have to raise the injector flow rate in grams/sec to correct for the larger injector?
Car: Take
Engine: Your
Transmission: Pick
I don't know what WinBin is, I assume its similar to the TunerCat program? Anyway, as far as I know, all you have to do is go into "ECM Constants" table, and change your injector size to what you are currently running, and it should compensate for what you have.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
