No reply from other post, so Ill try here
Old Jan 29, 2001 | 10:57 AM
88gta305's Avatar
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
Originally posted on motor swap:
Well, the venerable 305 has now gone and has been replaced with a 4 bolt 350 with 9.6:1 compression, the 255 hp truck cam, and new heads, (NOT LO5).
The car has only a couple of hundred miles on it so far, and runs like a raped ape.
The low / mid range surge of torque is really impressive.
Nothing else has been changed. I am still running 19# injectors, and the stock ECM and chip.
Question, should I change the chip, and if so, to what.
Also, am I doing any harm running it as it is.
There is no sign of detonation, or running out of power until past 4500 revs, so the tpi starts to run out of steam.
Any help gratefully received.
Does anyone have any ideas?
The engine basically is the 255 hp truck motor, which produces immense amounts of torque. I feel this is what the tpi is designed for and would appreciate any comments.
Cheers
Richard
Old Jan 29, 2001 | 06:55 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Cheers
Richard
If your happy that's all that matters.
I'm a tuner.
I'm never happy.
I want to go faster longer and use less fuel.
I want instant response.
I want I want I want
I burn and erase
I burn and erase
I read
I read
I read
I experiment
I experiment
Rant off
My car is a thrill to drive.
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The injectors/chip and motor are ill matched, and you can either get a custom chip to make the best out of what you have, or get the 22# injectors and a 350 chip. Or you could get the 22# injectors AND a custom chip, and it will be a raped ape on steroids!
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
