305 / 350 difference in chip
Old Jul 6, 2006 | 11:09 PM
IroczInOz's Avatar
I remember changing the cylinder sizes or something similar in WinBin when I was using it.
I want to know is there anything else other then Fuel Injector flow rate needs to be changed in Tunerpro when working with 6E? I know they have different spark tables etc.. But I am mainly concerned about the constants. Do you need to change anything else if using a 350 chip in a 305? I don't see anything to do with the engine size or similar.
Old Jul 7, 2006 | 07:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
No displacement constant. The MAF reports airflow, so no need to know displacement. The injector flow constant will need to be correct for the injectors. The 305 & 350 use different sizes.
RBob.
Old Jul 7, 2006 | 10:15 AM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I think the 305 uses a 19# injector, and a 350 uses a 22# injector. If you use a 19# injector on a 350, do you change any settings in bin, or just up fuel pressure some?
Old Jul 7, 2006 | 12:01 PM
IroczInOz's Avatar
Yeah mate you change it in the BIN.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
NWAsonoma
Aug 18, 2015 05:45 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
