COLD START ?
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
COLD START ?
I wnted to know from the people who switched from the 32b ecm to the 6e did you unplug the cold start inj.? I made my chip by using a thermomaster chip for an 89 350 tpi and dissabling vats and (x) on the manual option and selecting 24# inj. now the car felt much slower and barly got second witch I can usually get third good. then the next day it would not start so I pulled the plugs and they were all fouled out I replaced them and installed a stock 88 350 chip and now it runs fine. what did I do? also with the thermomaster it seemed to chug at normal driving speeds 25-55mph speeds. it is almost like my car loves the stock chip. this is a moded car too I have my original 305 heads that were ported and polished and have 1.94" valves with a 5 angle valve job. 24# inj. 52mm throttle body. adjustable fuel reg. stock 350 tpi chip. dual filter air box from a Iroc, slp 1 3/4" headers, borla muffler. and slp roller cam 206/212 duration @.050" .480/.487 lift. aluminum drive shaft and wc t-5 trans.
I would think with all of this the car would respond well to a chip.
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Did you or did you not unplug the cold start injector? You definitely want to unplug it.
I advise to just pull the whole darn thing and install a cold start injector plug kit. I recommend pulling the whole thing because the CSI could be leaking fuel or causing vacuum leaks. Just get rid of it entirely. At the very least - unplug it.
Tim
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Tim
- Program your own PROMs!. Read my article to get started!
- Research and Experiment before asking questions.
- This is not a chip store. Go to the classifieds if you want someone to sell you a chip or give you a BIN.
Where are these cold start injector plugs available? Do they include a plug for both the CSI mount on the runners and the fitting on the rear of the left fuel rail? How much are they generally?
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Accel makes a block-off kit for around $50, but Street & Performance (www.tunedport.com) sells a kit for much less, maybe $25. All these kits consist of are a plug for the hole where the injector is and a plug for the end of the fuel rail where the cold start injector gets its fuel.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Greg,
Do you think that a good hardware store would have the plug for the fuel rail?
To prevent the 9th injector from firing (opening) just pull the electrical lead to the injector.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(58psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter.
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
next mod: 4.10 rear gears
Engine: 385 HSR
I'm not sure, unless they have a good selection of plugs as this one is probably metric knowing GM. I have mine disabled by removing the 3-amp fuse labeled CNK (or something like that) from the fuse panel since it supplies power to the cold start injector in the TPI cars. Pulling the connector off of the injector will work too...
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
<font face="Verdana, Arial" size="2">Originally posted by GregWestphal:
</font>
</font>
Necessity's the mother of invention.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
[This message has been edited by JakeJr (edited February 08, 2001).]
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
