Cold Start Injector Plug kit
Old Feb 16, 2001 | 12:23 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Cruising around Mike Davis' site I found the following.....
http://www.eecis.udel.edu/~davis/z28...start-plug.jpg
Old Feb 16, 2001 | 02:13 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I just installed one of those kits last weekend. Works great, although I've think that Street & Performance <www.tunedport.com> sells a kit for a lot cheaper than the $50+ that Summit or Jegs sells the Accel kit.
Greg Westphal
'87 IROC 305TPI/A4
Old Feb 16, 2001 | 02:46 PM
TRAXION's Avatar
Dayum Greg. $50 for that kit? Wow.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Feb 16, 2001 | 03:29 PM
kevinc's Avatar
Car: 1982 Z28
Yup, it's major cash for the Accel kit. S&P sells a cheaper version that caps the fuel rail and plugs the injector hole, can't recall how much but it's way less than $50.
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Feb 17, 2001 | 08:20 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I have the S&P version, and first, it isn't a kit. YOu have to buy the runner plug, and the fuel rail plug seperatly. And frankly, you get what you pay for. My runner plug is just a round plug, thats it. It has no means of fastening it to the runner, I had to RTV it in place. Notice the Accell one has a bracket to hold it in place, this is GOOD. If I ever put a supercharger on my car, I'm sure that "glued in" plug will pop out. Very bad design. For both pieces it was like $30, I'd rather spend the extra $20 for the whole "kit" from Accel if I had to do it again. Just my $.02
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors, Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
--&gt;14.97 @ 94.9 MPH&lt;--
'97 Bonneville SSE
Old Feb 18, 2001 | 12:08 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
still have my cold start inj. on my bird but, was thinking of just buying the fuel rail plug is it an easy to find size and thread or do I have to buy a special one?. I already have the 89 runners so I don't see a problem there.
Old Feb 18, 2001 | 11:02 AM
a73camaro's Avatar
For 50 clams, I can live with the cold start injector.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
