tbi programming in a tpi computer?
Old Feb 22, 2001 | 10:58 PM
Project 92 RS's Avatar
Car: 1992 RS
Engine: 5.0
Transmission: auto
Axle/Gears: 3.08
I was just wondering if it was possible. I've just begun reading/learning about programming proms and I was thinking about this in terms of the tpi eproms having a faster baud rate. If it is doable, wouldn't it benefit the tbi programming as far as having a laptop hooked up. Faster rate would mean more data points, right?
Old Feb 23, 2001 | 12:25 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
My dad tried to use a 7730 TPI computer with his stock TBI setup in his 92 RS. It didnt work. The car was way too lean, even with 72lb injectors and the fuel pressure over 50lbs. We tried a custom chip in it, but it still wasnt enough. Rather than mess with it any longer, he finished the conversion of the top end to TPI, and gained 17 HP and 70 TQ at the rear wheels.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Feb 23, 2001 | 07:52 AM
FastBroker's Avatar
The TBI ecus are plenty fast enough to run any sort of TBI engine you can think of. Pleny fast enough baud rate. ALDL/Scan tool refresh rate is another story...
Old Feb 23, 2001 | 11:44 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Project 92 RS:
I was just wondering if it was possible. I've just begun reading/learning about programming proms and I was thinking about this in terms of the tpi eproms having a faster baud rate. If it is doable, wouldn't it benefit the tbi programming as far as having a laptop hooked up. Faster rate would mean more data points, right?</font>
TBI in a TPI ecm won't work. Well, given enough time enregy and money you mmight get something but would be lotsa work.
Totally different injector firing strategy.
Now using TPI to fire a TBI is possible. Dunno why the other guy couldn't get his to work, but I've run a 747 type system with a 730 ecm, also a 749. But, only momentarily since the injector drives are being overloaded in the 730 combo. The 747 uses (2) 1.2 ohm injectors and the 730 aren't wired for that low of P+H injector types. The 730 was used for a single 1.2, and the 749 for (4) 2.4s.
Old Feb 23, 2001 | 10:04 PM
steve8586iroc's Avatar
Would it be to involved to swap drivers from one ecm to another? Using tbi drivers in a tpi ecm.
Old Feb 24, 2001 | 08:51 PM
Would it be possible to run tbi drivers off the output of a tpi driver? Would there be a conflict of output voltage versus input voltae on the drivers?
Old Feb 24, 2001 | 10:04 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by steve8586iroc:
Would it be possible to run tbi drivers off the output of a tpi driver? Would there be a conflict of output voltage versus input voltae on the drivers?</font>
There is or was a group buy for doing just that at EFI332. One thing I want to try is using a 747 to run 4 injectors.
You could use this same setup for having a 730 run them.
You need to figure out what injectors your using and then try and get the Cherry Semiconductor ther are 2 different ones ie 1.2 or 2.4 ohm P+Hs
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
drathaar907
Aug 6, 2015 04:20 PM
