Bin definitions
Old Jul 11, 2006 | 08:08 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Bin definitions
Im looking for a little help. Im a newbie to chip burning. I just got my chip burning item from moates with all sorts of adapters and chips. Im using tuner pro. I was able to read my stock chip and save it to my computer. I need a bin defenition file for the 730 ecu for SD TPI (8D). Ive looked at the ones through turner pro and the ones listed from links to sites in the guide in this board. Im not sure which one to use? Can someone point me in the right direction or possibly email me one that you guys like to use? Thank you
Old Jul 11, 2006 | 09:31 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
welcome to the world of rolling,.. i mean burning your own.
read the stickies at the top of this board, go slow, make small changes, take lots of notes.
TunerPro and TunerPro RT - Professional Automobile Tuning Software
$8D is the second one in the list, Super_8dm2.ecu is what you what.
you'll need the ALDL Definition also, 1227730_8D.ads
you'll need to import the Super_8dm2 into TunerPro, the import feature in located in the XDF tab.
there are also some others out there, i use 3 different Bin Definition files depending on what i want to change, but the
Super_8dm2 is the main one i use.
Old Jul 11, 2006 | 09:49 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Ok thats the one I dowloaded. Im just having a problem understanding what all the flags stand for. I also need to find the power steering pressure switch flag.
Old Jul 11, 2006 | 10:55 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Welcome to the show
Address 19, bit 6. Set = PS Switch installed
The IAC has some steps added to raise the RPM when the switch is detecting a "cramp" in the steering so you don't bog down with the load. Also adds to the RPM when A/C is on and the cramp is detected.
I don't use it though.
HTH
Lots of reading in the stickys and searching posts will yeild most of the answers.
Old Jul 12, 2006 | 05:20 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Thank you. Ive been reading alot. I even brought two books the TPI swappers guide and how to tune and modify chevy fuel injection.
grngryoutmyway
Oct 18, 2016 05:48 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
okfoz
Sep 22, 2015 03:37 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
