How to erase EEPROM ?
Old Mar 2, 2001 | 02:55 PM
Blade's Avatar
One thing I didn't see mentioned in the other thread is how to erase the 29C256 prom ? I assume one of the pins needs to be hooked up to a switch or something to switch voltages ? Does the pocket programer have the ability to erase them ?
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
Old Mar 3, 2001 | 10:10 AM
Blade's Avatar
What... is it too stupid of a question ? lol
Old Mar 3, 2001 | 10:16 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Yes. The Pocket Programmer flashes it.
[This message has been edited by Glenn91L98GTA (edited March 03, 2001).]
Old Mar 3, 2001 | 01:44 PM
Blade's Avatar
Ah! Thanx
Old Mar 4, 2001 | 12:56 AM
Bob Wooten's Avatar
so what does "flashing it" mean? does that mean that it writes 0's to all the addresses & then downloads the new image after that or that it just downloads the new image & then does a checksum or somthing like that to ensure that it is right?
not trying to be a smart ___, just catching up w/the rest of the class.
thanks
BW
Bob Wooten
r71chevy@earthlink.net
www.r71camaro.homestead.com
Old Mar 4, 2001 | 06:48 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
You may want to check this site out:
http://www.howstuffworks.com/rom4.htm
It gives pretty good non-technical descriptions:
Instead of using UV light, you can return the electrons in the cells of an EEPROM to normal with the localized application of an electric field to each cell. This erases the targeted cells of the EEPROM which can then be rewritten. EEPROMs are changed a byte at a time.
89 Firebird Formula
WS6 package,ZZ4 Crate engine
SLP 58MM TB, Edelbrock TES Headers
Random Tech 3" cat, SLP 3" stainless exhaust
9 bolt rear, Hotchiss swing arms, Lakewood panhard rod
Corvette 2/4 servo, kevlar band, full poly rear.
Centerline 16x8 rims, B.F Goodrich drag radials
Old Mar 4, 2001 | 04:13 PM
Bob Wooten's Avatar
cool, just what the doctor ordered. simple, direct & good enough to get me there.
thanks amigo,
BW
Bob Wooten
programineproms
Oct 10, 2001 02:50 PM
okfoz
Jun 21, 2001 10:11 PM
ws6transam
17
Apr 4, 2001 12:03 PM
Kevin91Z
52
Mar 31, 2001 10:59 AM
