What is "flash" programming
Old Mar 6, 2001 | 12:25 PM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
What exactly is "flash" programming? My car is getting Dyno Tuned and they said that that is what they are gonna use for one of the tuning techniques.
1988 GTA 5.7L TPI Auto
355 ci. block, SLP Cold Air Intake w/ K&N, fully modified MAF Sensor, TPIS 52mm Throttle Body w/Air Foil, Fully Ported and Polished Plenum, Nikel-plated Ported SLP Siamesed Runners, Ported TPIS Big Mouth Intake Manifold, stock heads w/ 1.52 Comp Cams Self-aligning Roller Rockers, TPIS ZZ-9 Roller Camshaft, TPIS Valve Springs, Cloyes True Double Roller Timing Chain, TPIS Adjustable Fuel Pressure Regulator, Balanced Bosch 22 lb/hr Fuel Injectors, MSD 6AL, Taylor 10mm Wires, Bosch Platinum +4 Spark Plugs, MSD Blaster Coil, March Underdrive Pulleys, 6 3/4" Vibratech Streetdamper, TPIS Level 4 PROM, 160 T-stat, Low Temp. Fan Switch, Stock Distributor w/ Bronze Gear, SLP 1 3/4" Headers, Random Technologies High Flow Cat., Adjustable Borla Cat Back Exhaust, Flow Tech Pre-Cat 3" Exhaust Cut Off, Level 10 PTS-3 700R4 Trans, B&M Holeshot 2400 Stall Converter, B&M Trans Cooler, TCI Aluminum Finned Trans Pan, Torque Converter Lock Up Switch, 3" Balanced Aluminum Driveshaft, 3.73 Richmond Gears, Auburn Pro-Series Differential, Aluminum Differential Cover w/ Main Cap Preloads, BF Goodrich Drag Radials 255/50 R16, Hotchkis Lower Control Arms, Hotchkis Panhard Rod, Hotchkis Tie Rod Adjuster Sleeves, Bilstein Heavy Duty Shocks and Struts, 1LE Springs, Energy Suspension Polyeurethane Bushings, Global West Tubular Subframe Connectors, Global West Steering Box Brace, HP Motorsports 3 Point Strut Tower Brace
"Why ride a stang when birds can fly?"
http://www.geocities.com/thegta
Old Mar 6, 2001 | 04:50 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Joseph Andres:
</font>
Rather then burn eproms, there is a devise that emulates the eprom. They use a flash prom, which erases and can be rewritten quickly, some even on the fly changes. Usually $700-1000. For a pro shop a nice option.
Has noting to do with accuracy of tuning, just allows faster changes
Old Mar 6, 2001 | 07:00 PM
Grumpy,
Can you please specify a little further? Thanks.
Joe
Old Mar 6, 2001 | 08:16 PM
theformula's Avatar
Grumpy does this mean they re-program your prom permanently? Or just temporarily to tune? I'm confused...What exaxctly is the purprose of "flash programming"
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5275rpm limit),Holley 9mm wires,Ac delco R43ts plugs,fastchip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Mar 6, 2001 | 11:16 PM
Bob Wooten's Avatar
If I can but in, a prom is a memory device. it stores bunch of 0's & 1's. to erase a UV prom you have to expose it to UV light for some period of time & the load in the new image. an EEPROM is an Electrically Erasable PROM. this means that you can send it a signal (the basic idea here not specifics) erase the image & load a new on on. this takes micro seconds not minutes. an emulator has a EEPROM in it. you connect it to your computer & when you are ready to send it a new image you push the go button & Bang its there. a flash prom is basically the same as an EEPROM but the way that it erases it is slightly different. i trust that you get the point. as Grumpy said, the emulator (EEPROM, cable, program etc) setup is an expensive way to go for a person that is going to do one car, but for a shop that is going to do a bunch of them time is $.
HTH's
Bob Wooten
r71chevy@earthlink.net
www.r71camaro.homestead.com
Old Mar 6, 2001 | 11:19 PM
Bob Wooten's Avatar
Oops, in answer to your question, this is a temporary thing. they flash & flash & flash & flash until it is right. then when they are done, they save the image & burn it into your prom. power down the car, remove the emulator & stick the memcal with the "new" prom in it. power the cpu back up & go for a test drive. it ought to run like a new car.
BW
Bob Wooten
junior419
Apr 7, 2025 11:35 AM
RS Reaper
Oct 17, 2018 07:52 PM
ULTM8Z
Oct 2, 2015 01:25 PM
lewandom
Oct 1, 2015 08:15 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
