map sensor problem
Old Jul 17, 2006 | 04:43 PM
turbotater's Avatar
map sensor problem
i have been having problems tuning my typhoon
and i noticed why . my map reads a different value
than my boost guage . here are some numbers
at 19 inches vacuum my datamaster map shows 30 kpa
at 0 inches vacuum my datamaster map shows 70 kpa
at 16 psi boost my datamaster map shows 140 kpa 10 psi boost
i am confused at the scaling because i thought the conversion from
kpa > psi was kpa x .29 approximately
the guage i am comparing against i feel is accurate
this is on a 3 bar map
any ideas ?
mike
Old Jul 17, 2006 | 05:38 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
I thought the $58 for the Sy/Ty crowd was only a Beta version?
Might not be right to begin with.
Have you checked to see if there is a Tuner Pro file u could try temporarily?
later
Jeremy
Old Jul 17, 2006 | 10:30 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
any ideas ?
mike
If you installed a 3-bar MAP with the stock $58 code then the ALDL will not read properly and the ECM will not work properly.
You need a different equation for the ALDL datastream when using a 3-bar MAP sensor. Check the NWSTP site for the ADS file and look at the 3-bar MAP equation. I pressure tested a 3-bar MAP sensor with one autometer boost gauge and one automotive pressure gauge and the equation appeared to be correct when viewing the ALDL reported MAP value.
You need custom code for the 3-bar MAP sensor to work properly with the ECM. Be careful with the custom code/patch you use.
9192camaro
16
Feb 3, 2019 12:21 AM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
