MAT tables Ecm 7730
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
MAT tables Ecm 7730
I'm starting to play with the MAT tables in Tunercat 8D ver.P tdf.
My Question is, are the MAT tables in deg C or deg F.
The Table (MAT compensation counts Vs. MAT)
it starts at -40deg to 152deg.
I'm guessing It's in deg. F
Louis
Convertable
92 Z28 305tpi Auto
1/4 at 13.23 @ 106.1mph w/Paxton 10psi, Ram air mod,Water methanol inj.,52mm T/B,ASM Large tube runners, ported upper & lower intakes,AFPR,23# injectors,1.6 roller rockers,slp tri-y headers,3in. cat,3in. gale banks cat back system,3.42 gears,17x9 camaro SS wheels, 285x40x17 tires,and much more.
http://www.lbsz28blown.cz28.com
Louis
Convertable
92 Z28 305tpi Auto
efiguy
Sep 27, 2015 01:30 PM
