Converting O2 voltage to A/F Ratio?
Old Mar 27, 2001 | 03:12 PM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
I know that 450 mV is 14.7:1 and that the values change extremely fast on either side, but can you convert mV readings to A/F ratios?
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Mar 27, 2001 | 06:56 PM
Bob Wooten's Avatar
The short answer is no. the stock O2 sensore works great @ 14.7 but is VERY non linear @ the top & @ the bottom. there are some companies out there that will tell you that you can guess @ the AFR from the O2 reading but they are just educated guesses & they are +/- a LOT.
there is a long answer, a search of the archives will probably get you to it.
BW
Bob Wooten
r71chevy@earthlink.net
www.r71camaro.homestead.com
Old Mar 27, 2001 | 07:27 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Bob Wooten:
BW
</font>
What you want is a wide band O2 sensor. The oem gm's are a switching type.
So far they run at least 800, and usually closer to a Grand, but hopefully that will be changing soon!.
Old Mar 27, 2001 | 09:56 PM
Engine: 406
Thanks, that's what I thought and feared.
Old Mar 28, 2001 | 12:44 AM
Bob Wooten's Avatar
Like Grumpy said, hang in there, this too will pass, (hopefully soon) He has a ton of tricks up his sleeve.
BW
Bob Wooten
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
1992Z28!
Nov 19, 2015 07:33 AM
88rscamar0
Sep 23, 2015 09:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
