Forced Induction + TBI?
Old Mar 27, 2001 | 10:10 AM
Ken73's Avatar
Car: 82 Corvette
Engine: 350 CrossFire
Which ECM? Obviously this never happened in production, but there should be an ECM capable of handling this combination.. obviously a new MAP sensor (depending on amount of boost of course) is required.
Does anyone have any suggestions?
Would running a '7747 with a 2 bar (under 15PSI boost) be a bad thing?
Ken
Old Mar 27, 2001 | 10:20 AM
FastBroker's Avatar
I was wondering that same thing. It's GOTTA work, but gonna have to PROM change something wicked.
EDIT: ie, to bolt on a cheapo new blower, run less than 10lbs boost and use a 670cfm/454 OEM TBI unit. Good emmissions AND power AND cheap AND easy(?) AND plenty(?) of parts available.
Anyone else???
[This message has been edited by FastBroker (edited March 27, 2001).]
Old Mar 27, 2001 | 10:46 AM
Ken73's Avatar
Car: 82 Corvette
Personally I was thinking more along the lines of twin turbo on my '73 Corvette.. but I was also thinking of the guy in TBI that was asking about the B&M (Holley) supercharger as well.
Ken
Old Mar 27, 2001 | 11:03 AM
FastBroker's Avatar
Cool.
Old Mar 27, 2001 | 12:30 PM
Brent's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Ken73:
Ken
</font>
It seems to me this would be an easier route to take, because the OEM ECM's designed to handle boost are not plug and play with TBI.
With a roots blower the ECM would never read any boost since it is a draw through setup and the MAP is connected between the blower and TBI. I would bet you could use a 7747 to fuel a roots s-charged engine fairly easily.
[This message has been edited by Brent (edited March 27, 2001).]
Old Mar 27, 2001 | 08:03 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Ken
</font>
The trouble is that you run out of resolution for tuning when in boost, so you have to setr everything too rich early so you don't run out at the top end.
For oem 2 bar (boosted) systems you have the syclone/tyfons, Turbo Gran prix (91 ish), Turbo Buicks, and the late S/C pontiacs. Notice none of them at TBI. The superchargers can add alot of turbulence, and generate rich lean cylinders. I'd seriously look at doing something TPI wise
Old Mar 28, 2001 | 07:44 AM
Ken73's Avatar
Car: 82 Corvette
<font face="Verdana, Arial" size="2">I'd seriously look at doing something TPI wise</font>
Any suggestions on an ECM for a V8 with forced induction then? The list you show are all V6's, aren't they?
Ken
Old Mar 28, 2001 | 08:50 AM
Tomcat's Avatar
Grumpy if the map was sourced between the tbi and the blower it would never see boost it would just think the engine is soooo much more efficient / larger cubes.
Would this not work without loosing resolution as the boost the actual engine sees is dependant on the throttle blade position (or vacuum below thottle blades)
Old Mar 28, 2001 | 02:09 PM
Ken73's Avatar
Car: 82 Corvette
I think maybe this might be in order for the combination (TBI + forced induction)
Holley Commander 950
Anybody have any experience with these?
Ken
Old Mar 29, 2001 | 01:13 AM
Dan W's Avatar
Keep in mind that the larger of the TBI injectors (on a 2bbl setup) will only support a max of 400 - 450 hp.
Old Mar 29, 2001 | 10:29 AM
CanadianBeast's Avatar
One of my friends has single turbo on his tbi truck, and I'm not sure of the particulars but I know it's a stock tbi with the stock ecm and prom and it runs like crazy, for an otherwise stock pickup truck.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
