what buffer size should I use...or where can I find out.......
what programming voltage (VPP) should I also use.
86 tpi camaro
[This message has been edited by Z-BOSS (edited March 27, 2001).]
86 tpi camaro
It is all done automatically when you select your eprom type when you first start the program.
You would have a 16K chip if I remember correctly and your buffer area is from 60000 to 63FFF.
Quote:
<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
You would have a 16K chip if I remember correctly and your buffer area is from 60000 to 63FFF.</font>
appreciate it!!!!!!<font face="Verdana, Arial" size="2">Originally posted by Glenn91L98GTA:
It says in the instructions besre of the type and the Vpp Voltage your are programming. I saw the the 16k but I'm not sure if I choose 12.5v or 21v.
aslo when adjusting injectors to 24lbs, do I increase the single fire and double fire? Is that all or is that right?
Generally, I would expect them to be 12.5 volts. Try it and if it doesn't work try the higher voltage setting.
I have an SD car, so I cannot comment on the MAF "single fire vs double fire". My want to do a search on this to see what other MAF owners have done. I recall seeing this question being raised before.
MAF person to the rescue!
You want to change double-fire since our cars operate in batch-fire mode. Also, the proms we use are generally 12.5 volts from what I've seen unless other specified...
Greg Westphal
'87 IROC 305TPI/A4
You want to change double-fire since our cars operate in batch-fire mode. Also, the proms we use are generally 12.5 volts from what I've seen unless other specified...------------------
Greg Westphal
'87 IROC 305TPI/A4
