Innovate users respons time for WBO2
Old Jul 23, 2006 | 01:43 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi..
For you guys using innovate WBO2 what respons time do you have it at?
(instant, 1/12sec, 1/6sec , 1/3sec)
I have mine at instant right now and wonder if its ok to slow it down to have a more stable reading to tune after... or what do you guys think?
Running $58 code without learn activated...............
/N.
Old Jul 23, 2006 | 03:23 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Depends on distance from the exhausts valves, and RPM.
Mine is Very far downstream, and at cruise RPM, is probably about a .1 sec..
Old Jul 24, 2006 | 03:35 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Think i wrote the question wrong....
I mean is it ok to set the responce time to 1/12sec to get a more stable reading to tune after ( Innovate will the display the average AFR value for 1/12 sec instead of instant value)
The AFR is bouncing some at cruise and idle and it makes it difficult to tune after. WOT is pretty stable....
Mine is just below the collector on rh side, approx 25"away from exhaust valve.
Old Jul 24, 2006 | 07:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, I would slow it down. The 1/12 second should be OK. If not then drop down to the 1/6 second response.
RBob.
Old Jul 24, 2006 | 09:47 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Tested it to 1/12 today and It was alot easier to tune.
The only small issue befire boost is AE I get a rich bog no matter what I set AE vs TPS to.... and If I have TPS at 70% and the goes to 100% I get a lean bog......
Anyway.... part throttle and WOT without boost is ok now for driving............
/N.
BADNBLK
Nov 16, 2016 09:12 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
LT1Formula
Nov 16, 2015 01:13 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
