27c128
Old Apr 10, 2001 | 06:56 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
27c128
what cars came with the 27c128? I plan on going to the junk yard. I know what comp. will work but what ones have the right chip?
Old Apr 11, 2001 | 08:27 PM
Engine: ls1, LB9
btt
Old Apr 11, 2001 | 09:51 PM
CanadianBeast's Avatar
Read traxions article at the top of the page. At the bottom there is a table that says.
I know that the 89, 88, 87 and maybe 86 tpi cars had a 27c128. 90 or newer have 256's
Old Apr 11, 2001 | 09:56 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
88, if I understand your question correctly, you appear to be looking for the memcal as opposed to the physical eprom.
If this is indeed the case, you will need the memcal for an 88 TPI (if you have retained the cold start injector) or from an 89 TPI if you have dumped the cold start injector. This is for the "limp mode"...never know when you may get a sensor problem and need "limp mode" to get you home.
Old Apr 12, 2001 | 05:36 PM
Engine: ls1, LB9
well I just need the chip itself but, I wasn't sure if some other cars had the same chip because if they do than I could snage them out of the junk ecm pile. take them home erase them reprogram them and put them on my original memcal.
I wan't to do this to see if my chips went bad or if it really is the pocket programmer.
86camaroZ
27
Apr 21, 2010 07:52 PM
Craig Moates
Jul 4, 2003 05:51 PM
Clutch
Apr 23, 2002 07:43 AM
tpi_roc
Apr 13, 2002 08:13 PM
leirch
Mar 2, 2001 09:12 PM
