Using eprom as a scanner?
Old Apr 13, 2001 | 09:01 AM
BenDoe's Avatar
Is there any way to read the eprom to see what changes it has made in BLM. Ex. when the BLM is 108, the car is running rich, so the eprom leans it and then stores that mixture for later use. Just a thought, thank you.
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
Old Apr 13, 2001 | 10:23 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
BLM changes and such are not stored in the EPROM. They are stored in ECM RAM.
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's with bigger cam, bigger stall, and bigger exhaust.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Old Apr 13, 2001 | 10:40 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I personally don't believe the stored BLM values are relevant. If your scan tool captures data, then that would be far more effective to determine the modifications you wish to make to your eprom.
I've brought Tim's P730 - Part Throttle Fuel Tables (no PE) to the top of the posts which I think you will find very helpful in tuning the VE tables to get 128/128.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
whtltng89
Sep 8, 2015 07:06 PM
Electro_X
Aug 19, 2015 07:59 AM
mizz0313
Aug 12, 2015 06:45 AM
the_nikfive
Aug 11, 2015 02:46 AM
