Do I need Diacom?
Old Apr 9, 2001 | 02:34 AM
BenDoe's Avatar
Do I need Diacom?
Instead of spending the $200 for the software that allows me to read/store information from the computer onto a laptop, could i just hook up voltmeters to the oxygen sensor and the knock sensor and tune the chip from those? What other useful information can reading the computer give you that can help burning proms?
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
Old Apr 9, 2001 | 07:38 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
You can't log data with a voltmeter, nor can you read the data fast enough to know what to do with it. With a scan tool, Diacom, or most of the free programs, you can see all of the data the computer is seeing.
Greg Westphal
'87 IROC 305TPI/A4
Old Apr 9, 2001 | 08:25 AM
gravitar's Avatar
Well, if you had a voltmeter with RS232 port (these are actually getting pretty cheap these days) then you could log the data. But, as you said the sampling rate would probably be too slow to be useful. And, you'd only be able to log one sensor per meter.. You'd quickly approach the point where $200 software would be the cheaper alternative.
Old Apr 9, 2001 | 06:20 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Use a $50 ALDL cable and my free software. It'll log all the data you want to disk, as fast as you want it to. Unless you're really going to use it on a dozen different cars, it's hard for me to understand why anyone would want to spend over $300 to do what they can do for nearly free.
Check previous posts, it works just fine. No charge, open source.
Old Apr 13, 2001 | 11:12 AM
Mojo's Avatar
Where can I get an ALDL cable for $50?
Old Apr 13, 2001 | 11:52 AM
Bob Wooten's Avatar
http://www.mindspring.com/~amattei/akmelect.htm
Bob Wooten
71 Camaro, 91 EFI
r71chevy@earthlink.net
www.r71camaro.homestead.com
Old Apr 13, 2001 | 01:23 PM
Mojo's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Mojo:
Where can I get an ALDL cable for $50?</font>
He wants $95 for his cable. I'd rather pay $50, but you have to spend what you have to spend... After dumping over 15k into my engine, now is no time to start being a tight-a$$!!!
JPrevost
Jun 16, 2001 06:08 PM
Grumpy
May 29, 2001 03:53 PM
iroctpis
Mar 6, 2001 03:48 PM
88irocz
Jan 29, 2001 08:02 PM
John Millican
Jul 27, 2000 06:48 PM
