Canister purge
Old Apr 15, 2001 | 09:18 AM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Canister purge
What is the function of the canister purge?
86 IROC T5
MSD 6A
Summit cam
Flowmaster
AFPR
Lowered 1.5"
My own prom (finally)
Old Apr 16, 2001 | 10:07 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Mechanically: It keeps gas vapours within the "system" so they are recirculated and reburnt instead of just evaporating into the environment as they did in the old days. This is why the gas cap is not vented like older cars had.
Eprom: When your engine reaches certain parameters (On/off Speed, on/off MAP kpa, a range of BLM operation of your engine), it will function from 0-100% Duty Cylces. If you wish to invoke Highway Mode either the Purge Canister has to be operating with at least 50% Duty Cycles or you have to change this parameter to 0% if you hve not Purge Canister.
If you wish to disable the Purge Canister because you do not have one, you should set the enable MPH to 255 so it will never function.
Old Apr 16, 2001 | 05:51 PM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
How do I enable or disable this funtion? I have WinBin and Tuner Cat.
86 IROC T5
MSD 6A
Summit cam
Flowmaster
AFPR
Lowered 1.5"
Old Apr 16, 2001 | 05:56 PM
Car: Death Mobile
Engine: 666 c.i.
I have Speed Density, so the location and the speific parameters available are different for my engine. Get the 32 hac from DIY_EFI.COM and search for "purge". You should find all the parameters and location.
Depending on how your system enables it (Speed, temp, whatever), just set the "enable" parameter such that it is never enabled. IE, set Speed to 255 or Temp to 255 if that is what the $32 uses to enable the Purge Canister.
83 Crossfire TA
Jan 3, 2016 01:26 PM
BWilcox
Sep 20, 2015 12:19 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
