TPI conversion, no crank, no fuel pump.
Old Jul 27, 2006 | 06:59 PM
Al Miles's Avatar
Car: $150 82 Camaro
Engine: 406 when my ship comes in
Transmission: 6 speed Richmond (its that ship business again)
I've just performed a TPI retrofit into a 1986 Firebird S/E that was a CCC car.
The wiring system is a 1985 TPI repinned for speed density. I am using a 730 ecm with AUJP memcal from GMPD. I've installed a wire harness form a 1987 v6 fuel injected car inside as well.
The fuel pump relay clicks on, and off, but the fuel pump does not run. Also the starter relay clicks, but the starter does not engage. Is the AUJP memcal looking for VATS?
Where are some good places to start looking for power so I can get er running?
Old Jul 27, 2006 | 07:07 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Check the wires at the starter. Maybe you reversed them?
Old Jul 27, 2006 | 07:29 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Are you sure it is a 87 dash harness. I did not think that they had a starter relay. Or are you talking about the starter soleniod on the starter. And the AUJP memcal would be looking for VATS.
Old Jul 27, 2006 | 10:06 PM
Z69's Avatar
Z69
The fuel pump won't continue to run until the motor is cranking.
The ecm turns it on for a few seconds then stops it to pressurize the system.
Then once the ecm see's the dist. turning it will turn the FP on again.
Jumper the starter solenoid between the large terminal and the small one.
If it cranks fine, you don't have a power to the starter problem.
Which means it's your key switch,neutral switch, or the connecting wiring.
Assuming your car doesn't have a vats starter module.
And you will need to disable vats on your chip.
Old Jul 28, 2006 | 08:36 AM
Al Miles's Avatar
Car: $150 82 Camaro
the solenoid on the starter. I'm glad to hear that the AUJP memcal is looking for VATS while I have it apart. I've been having issues with my pocket programmer not being found by my PC... guess that's the next thing to do.
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
