ecm repinning swap question
Old Jul 27, 2006 | 03:09 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
stupid question probably, but it isnt obvious to me, when im looking at these diagrams. how do i know which way to look at th ecm to repin it?
Old Jul 27, 2006 | 08:22 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
730 connector layout (looking at the ECM with plugs removed)
Ignore the colors, they are from my setup.
Old Jul 27, 2006 | 08:36 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks im actually doing the 630 - 727 conversion and i have a conversion chart just says like pin a1 to pin b12. but i dont know how to recognize which way to look at the ecm since it has 4 equal sized plugs.
that may help in my translation however. thanks!
Old Jul 27, 2006 | 08:41 PM
JP86SS's Avatar
Oh well, I tried
If you look real closely inside the connector they are usually marked.
Hard to see but should be some indications molded into them.
Old Jul 27, 2006 | 09:59 PM
Z69's Avatar
Z69
Wire colors at the corners of the connector will tell you which connector your on.
Old Jul 28, 2006 | 03:10 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
1227727 Wiring Harness Pinout
does not give colors
i have to convert from 165 to 730 to 727
Old Jul 28, 2006 | 11:24 AM
JP86SS's Avatar
Its best to do it in stages.Draw yourself a diagram of each set of connectors.Start with the 165 and mark everything as it is on the 165 (including colors)Then draw the 730 with everything where tit needs to be, then the 727.then do a "goto" listing under each label of the 165 diagram.that will give you that conversion, then do the goto diagram from the 730 to the 727.THEN go back and look for shortcuts to remove the center process.Any other sequence will leave questions and confusion.Don't even attremp to do this by a list of "this goes there" type of thing.Somewhere in the middle a wire will not be able to be run where you need it and you'll start to improvise. That where the trouble will begin.Knowing what color wire you have "extra" for running those kinds of things will allow you to fully document the diagram for next year when you need to add/troubleshoot something. Note very carefully where you connect grounds and power together and the end connection points so they can be located in the future.A good solid plan will get you there sucessfully.
Old Jul 28, 2006 | 01:51 PM
Z69's Avatar
Z69
Poke around on DIY_EFI.
It will have the 727 diagram from the manual.
Or, buy the manual.
Old Jul 28, 2006 | 02:01 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i have the diagram from the 727 but its confusing me, showing stuff like o2 high and o2 low? and the conversion to the 730 ecm doesnt make any sense, i am going off http://www.eecis.udel.edu/~davis/z28/ECMs/86to92.txt
and 1227727 Wiring Harness Pinout
Old Jul 28, 2006 | 02:07 PM
Z69's Avatar
Z69
This is the question we are answering......
Not sure what it is you want answered now.
Old Jul 28, 2006 | 02:09 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
is it too early to claim insanity?
Frozer!!!
Jan 19, 2024 04:55 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
