Accel DFI users please read
Old Apr 22, 2001 | 06:54 PM
lexussc94's Avatar
I just started using dfi and I am having trouble installing an engine program, that someone sent me, into the ecm. It keeps saying "path not found".
The program is on a disc right now. Do I use edit file or ecm? How do I put this program into the calmap so that I can get it into the ecm. Any help would be great. Thanks
Old Apr 23, 2001 | 10:23 AM
87Z-ya's Avatar
There should be a file in your c drive for all your engine programs. I would copy it from the disk to that part of the c drive. Then you should have a function for " program ecu from a file"
87z 383,afr 190's, comp hyd roller(242/248-.540/.562,114 sep),Ported and polished mini ram, 30lb inj, 3.42 gears, tremec 5spd, , 1,3/4" slp headers, speed pro bank to bank-wb02.
"Just remember children, no man can beat you once youv'e found the cliterous." 'chef'
Old Apr 23, 2001 | 02:08 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
First you must copy the file into the "C:\Calmap\unvrsl" folder.
If you want to make sure you correctly copied the file then start calmap and choose "edit file" (you don't need to be connected to the ecu to do this) and when prompted for the filename just enter the name of the file you copied into the "unvrsl" directory.
To download to the ecu, start up calmap and turn the ignition key forward without starting the car. Now choose "edit ECU". Next, after you establish a link to the ecu, choose "Global" and then "program all ecu tables from a file", when prompted for the filename enter it just as you did before (offline)
GTAman
Mar 15, 2019 11:40 AM
tazs2000
Jul 15, 2017 08:44 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
marcusaw
Aug 10, 2015 08:13 AM
