Scan tool or laptop???
Old Mar 17, 2001 | 10:48 AM
precision350's Avatar
I am interested in burning e-proms and I was wondering if I should get a laptop or a scan tool. What are some of the things that you guys recommend. And how much better is a laptop than a scan tool? Thanks
Old Mar 17, 2001 | 11:08 AM
Blade's Avatar
Defintely a laptop. A scan tool wont tell you much.... and will have no data capture abilities. Plus you can do so much more with a laptop Like... burn flash eproms at the track! Hehe
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Old Mar 18, 2001 | 07:51 PM
Z-BOSS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Blade:
</font>
How much will a decent laptop program run..... ball park figures
Old Mar 18, 2001 | 08:36 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Pocket Programmer /w/ software: $120
486 Laptop: $100
ALDL Scan Cable: $10 (build your own, for God's sake!)
ALDL Software: $0, repeat, $0
Tuning Software: $0 for WinBin, or whatever for Tunercat
Voltage Inverter for Laptop: $30
Being able to hear what your car has to say and tell it what to do: $Priceless.
Being a DIY kinda guy instead of a Joe-Blow buy-it-off-the-shelf idiot: $Beyond Priceless.
Old Mar 19, 2001 | 11:01 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Blade and others, my scan tool (MPSI Pro-Link 2000 or something like that) does have the ability to capture data. It works fine for 1/4-mile drag-racing or checking things out while cruising (by capturing every 5th frame where it isn't critical to see every frame of data).
Craig, tell me more about the free ALDL software. I had done some research last year into this, but never got past that stage. It sure would be nice to use an el cheapo laptop to graph data instead of scrolling through the numbers and writing them down or trying to remember them.
Greg Westphal
'87 IROC 305TPI/A4
Old Mar 19, 2001 | 11:19 AM
FastBroker's Avatar
Craig, looks like we have another taker of your software "capturing" data. ie to an Excel spreadsheet!?!?!??? Please help us!!! I will gladly pay you for a cable, BTW...
Old Mar 20, 2001 | 08:38 PM
Car: 87 T/A
OK, the software is at:
http://members.tripod.com/moatesenheimer/gmecm
Read the documentation file e6-doc.txt, then download the software. The hardware is at:
http://www.geocities.com/steve3034/cables.html
Just let Steve Ruse know what you're going to use it on (year-make-model & ECM. This guy is making cables for Andrew Mattei now.
-Craig
[This message has been edited by Craig Moates (edited March 20, 2001).]
Old Mar 21, 2001 | 07:46 AM
FastBroker's Avatar
Thanks, Craig. I'll work on it this weekend and see what I can do.
Old Apr 21, 2001 | 11:19 PM
james_fearn's Avatar
does this software allow you to view the captured data real time? does diacom? Is it benificial to view the data real time or do you mostly record a run and then review it later?
I guess something is better than nothing, and since researching this software, it sounds great and will help me get started (when i upgrade my ecm and engine).
James
1985 Z-28 305 TPI
221,000+ mi., Original Eng.
Old Apr 27, 2001 | 12:02 AM
BenDoe's Avatar
Will craigs software work with the cable that you build yourself with a 12v power supply?
1991 Z28 305 5spd 1LE, TES headers, dual cats, 3 Chamber flowmaster, Comp cams .488/.495 212/218 the usual street racer with a stock chip.
Gained 20HP by porting and polishing my EGR passage.
92projectcamaro
Dec 8, 2015 12:25 AM
1992Z28!
Nov 19, 2015 07:33 AM
Reid Fleming
Oct 10, 2015 09:56 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
RGB2015
Sep 20, 2015 09:26 PM
