stock PROM swap question
Subscribe
Apr 25, 2001 | 08:28 PM
Vader helped me with a fuel delivery problem over on the engine tech board (long story short: did an engine swap 305-> 350, having fuel delivery problems due to EGR and PROM)and suggested that I swap out the PROM I'm using (stock 305) for a stock 350 PROM. While this won't get me optimum performance it'll help with the fuel delivery problem until I can afford to invest in burning my own PROMs.
But can I use the stock 350 PROM if my car is a 5-speed? IIRC, GM didn't make a 350 with a 5-speed. So won't a stock PROM from an 89 350 Formula give off codes?
Thanks for the help.
Maverick
1989 Formula 350 TPI
5spd Tremec 3550/TKO
several suspension mods
Reply 0
Apr 26, 2001 | 02:38 AM
I used a stock 305 5-speed chip in my 350 5-speed car for a year, and had no problems with it. I also tried a 350 automatic chip, and the only difference I noticed was the shift light didnt come on.
Now I do my own chips and I have it set as a 350 5-speed.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Reply 0
Apr 27, 2001 | 11:12 AM
This brings up another question -- how difficult is it to simply burn a chip like that? Would I just have to load up the stock 350 bin, then change the variable for the transmission only? Or would I start from scratch and do everything (spark, timing, etc)?
Maverick
Reply 0
Apr 27, 2001 | 11:30 AM
Maverick,
I don't see if you have alumin heads or not, but what i did was use the 89vette 6speed chip(APYP.bin). I then disabled vats, egr, and whatever else i felt was neccasarry, and of course i changed the injector size to 24lbs. It runs great now!, of course it needs tuning but i'm going to wait till the Speed Density is ready to go in.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Reply 0
Subscribe
