Changing from $32B to $6E ARAP??
Old Apr 30, 2001 | 10:58 PM
87ColdAirIroc-Z's Avatar
I did some research and am still unsure of what needs to be changed to use the ARAP.bin on my car. The Vats is easy to disable. What else do i need to do? If i need to use my stock settings how can i figure them out. i do not have a $32B .ecu file for winbin?
87 Iroc-Z 305 TPI
Dynomax exhaust
modified MAF & airbox
3-10" JL subs
Eclipse components
Old May 1, 2001 | 07:40 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
You'll need to change your spark advance table back to the stock '87 settings, change the open loop tables (vs. rpm and vs. coolant temp), change the idle speed vs. coolant temp table to suit your preference , injector constant (flow rate), fan on/off speeds to work with your thermostat temperature and/or preferred operating temperature, Power Enrichment tables (fuel and spark advance), and maybe some other little stuff that might not make a difference. I switched over to the $6E code late last year, starting with the ARAP bin, but using the settings from my modified '87 bin.
Greg Westphal
'87 IROC 305TPI/A4
Old May 1, 2001 | 09:54 AM
Desert86Roc's Avatar
Greg, I am not sure all of that is really necessary. Of course, it doesnt hurt to try it, but just to get started, all I did to use the ARAP.bin is to:
- diable VATS
- change injector flow rate
- change fan turn on to match my thermostat better (dont even need to do this, but I recommend lowering the fan turn on temps)
Nothing else needs to be done to get started. Not even the spark tables. The arap tables seem to be a good place to begin. I went from the updated GM $32 code for 86 to the $6e arap with just those changes and dropped .3 off my ET, and gained 2-3 mph.
Old May 1, 2001 | 11:02 AM
How can i find the stock 87 settings if i do not have a $32B .ecu file for winbin?
Old May 1, 2001 | 09:43 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
You could go either way. I took the ARAP bin, put most of the values in from my 88 ADS chip, and went from there. I figured I would start with a bin that works, then change the numbers slowly towards the ARAP bin. I am only on my 4th chip, but I just started driving the car a few weeks ago. I think the main spark advance curve is too aggressive for a stock TPI motor. I have my initial timing advanced to 10deg, but I will be going back to stock 6 deg, and start increasing the table values. That is one area that I don't want to push too far!!!
Enjoy.
Best ET 14.413 @95.57 without
pulling valve covers or manifolds.
Also with stock 2.77 rear end!!!
Stell1579
Mar 25, 2003 12:01 AM
CRAZ28
Jan 17, 2003 07:05 PM
Allan
Aug 11, 2002 08:58 AM
RedIrocZ-28
Aug 5, 2002 12:29 PM
