Just got the stuff to burn PROM for TPI GMC, any sugestions?
Old Jan 15, 2003 | 07:26 PM
CRAZ28's Avatar
I just got the pocket programer and tuner cat and am going to burn a chip for my 89 k1500 GMC (specs in sig below).I was going to start out with ARAP. Any suggestions on changes I should make to ARAP for my application? Any better bins I could try?
Old Jan 15, 2003 | 09:07 PM
funstick's Avatar
which ecm, broad cast code or mask id etc ?
Old Jan 16, 2003 | 06:19 PM
CRAZ28's Avatar
I'm using a 165 ecm. Would another ecm be better?
Old Jan 16, 2003 | 07:15 PM
kevinc's Avatar
Car: 1982 Z28
Well...going by the specs in your sig you referenced earlier...whatever you do, make sure you don't, under any circumstances or for any reason, run a
Old Jan 17, 2003 | 06:31 AM
CRAZ28's Avatar
What??
Old Jan 17, 2003 | 11:47 AM
kevinc's Avatar
Car: 1982 Z28
That was smart-azz way of pointing out the sig you referenced isn't there...
Old Jan 17, 2003 | 05:59 PM
CRAZ28's Avatar
Ok, It's a 89 GMC K1500, 350 w/ 86 tpi and 165 computer, 10.3 to 1 comp., 1.6 roller rockers, 89 iroc roller cam,headers and free flow exhaust, jacobs ignition, Trick flow heads, descreened maf. I know I need to disable the csi to run the arap bin. Any other suggestions?
Old Jan 17, 2003 | 07:05 PM
kevinc's Avatar
Car: 1982 Z28
Ah, gotcha. Disabling the CSI is just disconnecting the electrical connector and securing it out of the way, you can later buy a plug set to cap the fuel rail fitting and cover the hole in the runner plate.
Get set up to capture ALDL data and see what's happening, tune accordingly, and it should be a real puller.
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
