Any support for 94 & up ecm's?
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I'm familiar with all the software and hardware for the 165's and 730's in our cars but have taken on a new project. I need to scan a 94 T/A (for ses codes). Does moates or tunerpro have scan software for these cars?
These 94 and later ecm's do not have a removable prom correct? Do you have to have expensive hardware to re-program these ecm's? Is the only alternative reverting back to a 1993 730 ecm?
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Try tunercat :-)
Should help you out.
93 were chip and I believe 94 up were flash? Memory is failing at the moment.
I dont remember the cable/flash/software for the flash obd1 cars being all that bad cost wise. Little more than the conventional stuff and a lot less than your normal OBDII setups.
later
Jeremy
later
Jeremy
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
