code43 patch in xdf?
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Almost certainly, but before we can tell you how we'd need to know what ECM and mask you're talking about.
it's an 8746 ecm with a 61 mask. I'm using jprevost 61v2.xdf and the stock ANTT bin. I've already done the rev limiter and code43 patches, the rev limiter patch is in the xdf and I want to add the code43 patch.
Transmission: T5WC
From the hack available here:
File Manager - Browsing directory /5) Source Code and Hacks/
Code:
LD43C: FCB $F3 ; 1111 0011, 243 ; b7 code 43, ESC failure ; b6 code 44, O2 Lean ; b5 code 45, O2 Rich ; b4 code 51, EPROM error ; ; b3 code 52, Cal-pack missing, (NOT USED) ; b2 code 53, VATS, (NOT USED) ; b1 code 54, Fuel pump relay malfunction ; b0 code 55, ADU Error, netres/RTS ovrrun
Transmission: T5WC
New flag.
Set the address to 43C.
Set the bit number to 7.
Name it Code 43 or whatever you want.
Click OK.
Click OK.
