What total ignition lead is best for N/A cars?
Old May 14, 2001 | 08:02 AM
89vette's Avatar
With PE spark advance set to zero, I'm running 32 degrees at 3600 and 192 LV8 up with no knock. Since WOT runs are going to kill me or get me thrown in jail going 125 all the time, I thought I'd ask what other people think rather than increasing it one degree at time. Is not 36 degrees usually the best lead for NA motors if there is no knock?
89 Six Speed FX3 coupe
More Performance 396cid specs:
Callies 4340 crank 3.875 stroke
Lunati Pro-Mod 5.85" rods
SRP Pistons 14cc dish
Comp Cams Custom cam 550 lift 220/229 duration
10.8:1 compression
AFR 195 competition ported heads
Miniram and TPIS 1 3/4" headers
Old May 14, 2001 | 09:45 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
More timing is not always better. A more-efficient head will need less timing than a lesser head. For example, the LS1 heads flow better than nearly any aftermarket heat out there, and the numbers those engines are putting out with mild mods are just phenomenal. The ones I know of are finding best power at 29-32 degrees total timing. Yes, it'd be safe and smart to only advance it 1 degree at a time until you get knock, then back it off 1-2 degrees from there just in case.
Greg Westphal
'87 IROC 305TPI/A4
Old May 16, 2001 | 02:31 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by 89vette:
</font>
36d is for like 76cc chamber. In a word it's just so large that it takes alot of timing for burning to get done. With 58cc AL heads 28d can work just perfectly.
General statements of x-y- or Z is what the magazine jerks use. They are still hyping info from flat head ford days, when 60 Octane gas was used.
Old May 16, 2001 | 02:51 PM
89vette's Avatar
Grump,
They shop that built my motor has an engine dyno and uses Motec DFI. 396 LT4's like 35 degrees total (CNC ported heads 58cc chamber)he claims. He also shoots for an AFR of 12.8 at peak torque and 13.0 from there to max RPM. I have 58cc chambers.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
customblackbird
Aug 15, 2021 10:16 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fronzizzle
Aug 9, 2015 01:15 PM
