Haltech
Old May 15, 2001 | 11:21 PM
derrel's Avatar
Haltech
1st post! Has anybody out there had any experience with the Haltech GM replacement ECM that allows laptop programing?
Old May 16, 2001 | 02:33 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by derrel:
1st post! Has anybody out there had any experience with the Haltech GM replacement ECM that allows laptop programing?</font>
I'm an ex owner of one. Tech support here in the states was lacking. It's an australian unit. DIY-EFI probably has some current users
Old May 16, 2001 | 02:55 PM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
I am using the Haltech E6GM. So far I am pretty happy with it. It was relatively easy to learn, and was pretty cheap ~$650. To install it, I just repinned the stock harness connectors. Make sure the company you buy it from has used the Haltech and will provide tech support. I purchased mine from Force Fuel Injection. www.force-efi.com
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
devilfish
Jan 25, 2003 10:47 AM
a73camaro
Mar 31, 2002 10:12 PM
MikeC.86Roc
Nov 9, 2000 02:31 PM
TRAXION
Nov 6, 2000 06:28 PM
