'89 stock 305 bin
'89 stock 305 bin
I am looking for an 89 stock 305 bin to compare with the arap.bin. If any one knows of one please let me know. my 89v4.ecu file should work to read any 89.bin correct?
thanks
jake
also: does any one know the flow rate for stock 87 305 injectors?
87 Iroc-Z 305 TPI
Dynomax exhaust
modified MAF & airbox
3-10" JL subs
Eclipse components
[This message has been edited by 87ColdAirIroc-Z (edited May 16, 2001).]
thanks
jake
87 Iroc-Z 305 TPI
Dynomax exhaust
3-10" JL subs
Eclipse components
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
APYM is a bin for the '89 305TPI/A4. Gears won't matter too much, maybe just some small changes to the main spark advance table. You can download this bin from :
ftp://ftp.diy-efi.org/pub/gmecm/bin_lib/
Yes, the 89v4.ecu file will read any '89 bin correctly. The stock injector flow rate for the 305 is 19 lbs/hr.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
ANZA attached.
ANZA is the most recent CA emissions 5.0 TPI M5 bin GM released. 1227165 ECM, $6E code mask.
