Whats the best Eprom programmer for the money??
Old May 16, 2001 | 08:54 PM
ChevelleCLM's Avatar
I just got my TBI going in my chevelle, and I have a 747 computer, but the problem is that it is out of a 4.3 ltr Astro Van. The car runs, but cuts out at anything over 3000RPM ,and idles funny, and does various other expected things. I am in desperate need of a programmer. Anyone got an old one laying around? If I have to buy a new one, which is the most programmer for the least ammount of $? If anyone wants to help me out and get me running until I can get a programmer of my own that would kick *** as well. Email me and I will send you a BIN that I think would work ok for me.
69 Chevelle 2dr hardtop blue, bench seats, 12 bolt w/3.73's muncie 4 speed. best 14.5@90
Old May 16, 2001 | 10:31 PM
leirch's Avatar
What you could do(until you get the programmer). You could see about going to a boneyard and find a vehicle that uses the same computer(truck maybe?) and see if you can grab some of those proms, running that astro prom is definatly not good(i'm assuming you have something greater than a 4.3 v6).
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old May 16, 2001 | 10:37 PM
LOL I have a 350 with headers and alum intake and worked heads. A little far from a v6. The boneyard that I got these from is pretty short of v8 computer controlled cars and trucks. I have like 4 747 ECU's and wiring harnesses, but no Eprom that works good. Anyone elese? maybe I could trade a TB, computer, harness, or whatever enyone elese might need for a programmer?
Old May 17, 2001 | 10:17 AM
Brent's Avatar
It sounds like you are currently running a V6 EPROM and calpak (the smaller chip). In addition to using a V8 EPROM, you will want to pick up a V8 calpak at a GM dealer. Part #16060836
I'm not sure if the V8 EPROM will even run with a V6 calpak installed in the ECM.
Old May 17, 2001 | 01:55 PM
leirch's Avatar
I didn't think TBI had a memcal? I thought they just had a prom?
Old May 17, 2001 | 04:11 PM
Brent's Avatar
The 747 has two removable chips. An EPROM and calpak (aka netres). The calpak contains the limp home stuff.
The 8746 and 8063 have the calpak soldered to the motherboard I believe.
Old May 17, 2001 | 04:23 PM
OK so anyone got any good ideas on where I can pick up a programmer for cheap?
Old May 24, 2001 | 06:33 PM
Warlock's Avatar
http://www.logicaldevices.net/suppor...usky/index.htm
I bought this one. Hooks up via the paralel port. Software is DOS, but programs great. Had to set my paralel port to normal in CMOS instead of EPP to get it to work. $99 for a new (well refurbished) programmer is the best I could find.
Old May 24, 2001 | 07:28 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by ChevelleCLM:
</font>
I've had real good luck with my Pocket Programmer. Maybe someone has their URL. 3 years old an probably just shy of 600 chips.
My Needhams started acting goofy at times with anything that was win95 or newer on it.
Thou it probably did a 1,000+ chips
Old May 24, 2001 | 07:40 PM
OK I got an old programmer from the college I go to, now I am burning the chips, but none of them seem to change anything when I plug them in . Still the same"runs good cold" runs bad hot thing going on.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
