Pump Shot vs Diff TPS and Diff MAP
Old Jun 2, 2001 | 01:05 PM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
If I make a change in the PS vs Diff TPS should I also make an increase of some sort in the PS vs Diff MAP? Maybe an entry level question but I'm an enrty level kind of guy.
thanks,
Lars
Old Jun 2, 2001 | 01:25 PM
Brent's Avatar
Good question. I'm also curious to know what conditions and when it is proper to change the Pmp Shot VS diff MAP.
I'm also curious as to what part, if any, of a Carburator the PS vs Diff MAP emulates.
Old Jun 2, 2001 | 01:57 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by lars92RS:
</font>
Nope, they are totally independent for when you use what. They are like the discharge nozzle size, but don't change the duration of the shot like nozzle sizes do.
On some cars a change of "1" makes a ton of difference, so go slow. When first tinkering I tried 3 one time. Made it about 4 blocks and had to put the old chip in.
BTW, ALLOWS carry your last chip with you just in case.
Old Jun 3, 2001 | 04:16 PM
lars92RS's Avatar
Car: '92 RS
Engine: In pieces
Thanks for the advice. I scaled both by 1.125. I gueess I'll be changing them back.
lars
Old Jun 3, 2001 | 07:11 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
</font>
I never make over a 10% change in anything unless I really really sure about what's going on.
Old Jun 3, 2001 | 10:59 PM
leirch's Avatar
Depending on the scale of a table, if the total of a table is 100, i usually change things in .4 or .8 increments, if the table is in percents i change it by 1-2, maybe 3-4 if its way off.
IE, tables in 100(VE tables), i did the .4-.8 changes
tables in percent(open loop clt vs. afr) i did the changes of 1-4percent.
Brendan
92camaroJoe
Jul 29, 2023 07:57 PM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
