COLD Open loop start ups
Old Jun 4, 2001 | 11:59 AM
leirch's Avatar
Ok, here goes. When i start the car cold, the idle goes to 1500rpms and then right back down to 1000-900rpms, shouldn't the car be holding the rpms up at around 1500+ when its STONE COLD?
For some reason mine doesn't??
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Jun 4, 2001 | 04:03 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by leirch:
Brendan
</font>
There are no universal this is the proper choke setting. There are so many calibrations, and each with it's own little tweaks, impossible to say.
On my cars I never use a choke rpm higher then 900, and set the max IAC count to just higher then that. So my ice cold engine jumps to like 950ish, and then immediately drops to 900. BUT, that is just what works for me.
jklein337
Sep 19, 2018 06:23 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
drathaar907
Aug 6, 2015 04:20 PM
