6E ecm constants
Old Jun 6, 2001 | 02:21 AM
drive it's Avatar
6E ecm constants
Hi y'all. I've been absorbing a lot here, finally registered. I've got a question about the 6E ecm constant "DFCO". Function? What the heck does it stand for? I've been working with the 32 and 32B on tunercat and I'm going to the ARAP now. Also with the 32 and 32B there is an adjustment under constants to increase threshold for a code 33, but on the 6E its gone and instead I find a MAF vs. rpm diag. I tried changing the values in the diag. table but it still set a temporary code 33 when the gm/sec went over 45 at under 2200rpm.With my combo it occl. will hit low 50's gm/sec. Thanks in advance for the help.
86 406
Old Jun 6, 2001 | 07:58 AM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I had code33 problems galore with my 32B code, but when I went to ARAP all was well. Anyways, if you're going to use the 6E, you might want to do some hex editing (Hex Workshop, etc):
At address hex-0210, the value here (default=45) will specify the gms/sec MAF signal below which the code33 will be disabled. If you set this to a higher value (100 or so decimal), you should be in good shape. I haven't done it, so can't verify, but I am pretty sure this is correct.
At address hex-0213 you'll find the value representing the RPM above which code33 is disabled. The entered value*25 is the RPM value. Default is 128 (3200RPM), giving a lower value here should disable code33 at lower RPMs. Same disclaimer as above.
These numbers came to me in a dream...
Old Jun 6, 2001 | 02:58 PM
drive it's Avatar
Craig, Thanks, I'll try it! Any ideas on the DFCO?
86 406
Old Jun 6, 2001 | 04:01 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by drive it:
</font>
Decleration Fuel Cut Off.
On the turbo car I disable it as an anti-lag devise. On a N/A car probably helps roll down some, ie saves on brakes. For road racing I'd disable it for keeping some combustion chamber heat, especially with AL heads.
Old Mar 28, 2004 | 06:52 AM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
Let us know if the code 33 thing works!!! i need a solution too.
Old Mar 30, 2004 | 10:22 PM
rattle's Avatar
my solution for a code 33 would be to just disable the code flag.
add a ecu item in the flags area of tunerpro
set as follows
start address 01de
columns 1
rows 1
element size 1
check in front of Bit Mask (array of flags)
map name, fail codes 24 to 35
other side of screen now
x axis, leave all blank
y axis,
leave at rows 1-10
fill boxes like this
1 24 6 33
2 25 7 34
3 26 8 35
4 31 9
5 32 10
boxes 9 and 10 are blank.
now save info
you can now decide whether or not you want any of these codes
to set or not. checked=code diagnostic runs,
also codes 43-51 are at 01df
and codes 52-55 are at 01e0
Old Oct 10, 2013 | 12:25 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Re: 6E ecm constants
I know this is an old thread but is there a modern day way to shut off Code33 and code34 in Tunerpro. I saw the directions above but they didn't make sense. I'm a novist at best...
Old Oct 11, 2013 | 09:54 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
33 and 34 have a malf and threshold. If your tuning for a cam and keep popping a 33 raise the threshold. if your having 33 & 34 problems diagnose it don't just disable the malf.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
