removing some fuel.
Old Aug 15, 2006 | 12:09 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
removing some fuel.
In my speed density ecm, Since I am having trouble with my aldl port and cannot datalog yet, I know I am running quite rich still, In the VE tables, Do I raise or lower the numbers accordingly to make it run leaner? I need to do something until I can run the scanner to see where I am at.
Old Aug 15, 2006 | 03:35 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
you lower the numbers for less fuel, you really need to datalog and not guess
Old Aug 15, 2006 | 03:38 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Thanks, That's what I needed to here. I did lower the numbers ten points all across, But on my Drive, I could smell something, And maybe a lack of power? But Look, I'm running 42# injectors on my combo. Maybe setting the injector rate at 42 was good enough and the computer + o2 sensor can compensate?
I would datalog but I can't.
Old Aug 15, 2006 | 11:41 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Just lowering the VE tables will not work unless you are in Open Loop all the time.
CL BLM will drive the fuel right back to rich where the o2 constants indicate.
Adjusting the o2 constants is what you'll need.
Might try the R/L Offset vs Coolant Temp table at L84F6 as a crutch until you can fix it right.
Will subtract from all the 3 of the o2 parameter tables when not at idle.
Idle has its own settings.
Go down in 25 mv steps (not counts) to a max of 150 change and see if it improves. Don't go too far and watch your temps.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
HP52TA
Feb 3, 2018 10:51 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
