Where's this extra timing coming from?
Old Aug 15, 2006 | 07:54 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
LV8 vs Coolant spark bias = 20.04
Spark reference angle = 5.98
LV8 vs Coolant spark Table:
Code:
0.00	0.00	0.00	-2.11	-3.87	-5.98	-5.98	-5.98	-5.98
0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00
0.00	9.84	9.84	9.84	9.84	9.84	9.84	9.84	7.03
9.84	9.84	9.84	9.84	9.84	9.84	9.84	9.84	7.03
15.12	20.04	20.04	20.04	17.93	15.12	13.01	10.90	7.03
Portion of spark table at idle:
Code:
        32LV8   48LV8   64LV8
1000RPM 28.83   30.59	30.59
800RPM   26.02	 28.83	 29.88
600RPM   22.15 	 24.96	 26.02
So PLEASE explain this.... Why do I have 35+ degrees of advance?
Code:
Deg F	RPM	WBO2	SA Degrees
184.1	750	17.32	35.51
184.1	750	17.44	35.86
184.1	800	17.97	36.21
184.1	800	18.08	36.56
PS: I just tried burning a new chip using a stock apyp bin and the same thing is happening. I figured it could have been my hacked wbo2 bin doing it, but I guess not...
Old Aug 15, 2006 | 08:53 PM
Dirtbik3r's Avatar
I have got only 3 days to sort this out. The return to college and end of summer ran up on me pretty quick. I am puzzled about this. This has to be a bin issue, correct?
EDIT: I need to know for certain that the coolant temp spark correction bias is definetely 20... It seems if the bias was around 10, this would make sense where the extra spark is coming from.
Old Aug 15, 2006 | 09:52 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There can be additional SA added by the idle stablizer SA and after-start SA. If the EGR is active that too adds SA.
RBob.
Old Aug 15, 2006 | 10:00 PM
Dirtbik3r's Avatar
RBob.
I'm pretty sure the EGR is disabled. I just raised the disable egr if mat temp value to 304.25 degrees.
The idle stabilizer SA and/or after-start SA can scew the timing this much? I wouldn't mind, but the vortec heads do not like that much timing.
Old Aug 16, 2006 | 07:43 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
There is a 20-degree bias, but the table you listed has the bias removed. The LV8 axis goes higher left to right, and the coolant temp axis goes lower top to bottom, so at 184 deg. F (between the 3rd and 4th rows) the amount of SA added is zero. The table is used to add timing at really cold temps and remove some timing at really high temps. In the ARAP and other 6E bins, only 10 degrees of SA is added at the low temps (the bottom 3 rows), then 7 degrees the next 2 rows, then nothing added or removed until the top row.
Old Aug 16, 2006 | 10:13 AM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
ALDL spark adder still turned on???
Old Aug 16, 2006 | 03:53 PM
Dirtbik3r's Avatar
I wish that was the case. But aldl spark adder is disabled.
My version of tunerpro rt has the bias value listed under constants. The table is seperate. So if my bias was set to zero, you would see 20 filling in the upper part of that table.
Technically, this is the table:
Code:
20.04	20.04	20.04	17.93	16.17	14.06	14.06	14.06	14.06
20.04	20.04	20.04	20.04	20.04	20.04	20.04	20.04	20.04
20.04	29.88	29.88	29.88	29.88	29.88	29.88	29.88	27.07
29.88	29.88	29.88	29.88	29.88	29.88	29.88	29.88	27.07
35.16	40.08	40.08	40.08	37.97	35.16	33.05	30.94	27.07
Old Aug 16, 2006 | 06:13 PM
Dirtbik3r's Avatar
I got some new fuel to add...
Both yesterday and today, the timing is correct untill I drive down the road for 2min. And then it skyrockets - out of nowhere! Now, if I were to restart the engine, it would retain the skyrocketed figures. This is odd. It almost seems that when the computer "resets" itself, it retains the correct amount of timing untill I drive down the road??? When i say 2 minutes, I mean almost exactly that.
BTW, engine was about 185 degrees when it was correct.
EDIT:
Take a look at the attached Text document. I saved the csv file from the datarun to text because TGO won't let me attach a csv file.
The timing took it's wrong turn at sample 695. I really hope someone can make sense of all this...
File Type: txt
Old Aug 16, 2006 | 08:16 PM
Dirtbik3r's Avatar
Please .
Could I possibly have a defective ECM? Or is this definetely bin related?
Old Aug 16, 2006 | 11:14 PM
Dirtbik3r's Avatar
It seems that when I set my bias value to a higher value, evrything but idle seems to have close to correct SA.
Old Aug 17, 2006 | 02:34 PM
Dirtbik3r's Avatar
UPDATE: Ok, I just tried burning the chip on a different laptop and got the same story. I can't believe no one else has had this problem!
I start the car and timing is low even though I look at my spark correction table and there shouldn't be any correction. It then runs and almost reaches the right SA. Then, a minute later, timing skyrockets in the 40's. What is the problem here? Could this be a bad chip buffer or a bad ECM? How could I find out.
Also, lately, my engine is making my radar detector go off... It reads LASER and I start looking around to find no one. This related somehow?
I guess my older thread was the start of this problem.
Check it out.
https://www.thirdgen.org/forums/diy-...-sa-flaws.html
I need to make a 3hr drive up to school with this car in 3 days!!!!!!
If the bias value listed in tunerpro under constants is set to 20, then is my table correct?(the first one with the zero's)
Old Aug 17, 2006 | 02:50 PM
Engine: 385 HSR
OK, I know what you're talking about. There's a variable called Coolant Temp Spark Correction Disable Temp that sort-of disables the use of the LV8 vs. Coolant Spark table above this disable temperature. In the ARAP bin, it is set at 112.5 degrees F. The SA below this disable temp is controlled by the table, although it does add a few to several more degrees based on the amount of throttle. Once the disable temp is exceeded, the main SA table is now used, but if the LV8 vs. Coolant table has values that are more/less than the bias amount, then that amount (more/less than the bias) is added to the main spark table. This is from what I figured out a few years ago. I played around with the values and tables to tweak it, but forgot what I did and why.
Old Aug 17, 2006 | 04:32 PM
Dirtbik3r's Avatar
Alright, my Coolant Temp Spark Correction Disable Temp is set at 130.10 which is the stock disable temperature for the APYP. My timing is out of control!
Lets say the following arguments and conditions are met:
Coolant Temp Spark Correction Disable Temp = 130.10
Coolant Temp Spark Correction Bias = 20.04
Actual Coolent Temperature = 174.65
Engine speed = 2000RPM's
Engine Load (LV8) = 104
Spark Advance table value according to the previous LV8 and RPM = 34
Actual Spark Advance to TDC = 43.24
I was under the assumption that you take the Coolant Temp Spark Correction value and subtract the bias value. Now you add/subtract that to your main SA table.
If the above were true, 20-20+34 SHOULD BE 34!!! WHy do I have no control over my timing???
Old Aug 17, 2006 | 08:55 PM
Does your knock sensor work? Does APYP have a forced knock test?
Old Aug 18, 2006 | 12:19 AM
Dirtbik3r's Avatar
Does it function? -yes
Does it function properly - I don't know
I get KR at anything above 3800RPM's no matter what my timing is set at. I did notice that the single wiring leading to the sensor got melted from the headers. (The insulation, not the wire itself) I guess I'll fix this tomorrow to make sure this isn't causing my timing problems.
How does the Knock Sensor come into play here? What are you thinking of RednGold86Z?
Old Aug 18, 2006 | 07:30 PM
Dirtbik3r's Avatar
I'm confused...
My knock sensor works. I even put in a new wire going to it just to make sure and I cleaned up the connections.
I still don't know how this extra timing is coming in. To make it driveable, for now, I made the following changes:
Coolant Temp Spark Correction Bias = 30.59
Coolant Temp Spark Correction Table =
Code:
-10.55	-10.55	-10.55	-12.66	-14.41	-16.52	-16.52	-16.52	-16.52
-10.55	-10.55	-10.55	-10.55	-10.55	-10.55	-10.55	-10.55	-10.55
-10.55	-0.70	-0.70	-0.70	-0.70	-0.70	-0.70	-0.70	-3.52
-0.70	-0.70	-0.70	-0.70	-0.70	-0.70	-0.70	-0.70	-3.52
4.57	9.49	9.49	9.49	7.38	4.57	2.46	0.35	-3.52
Doing this, Things are pretty accurate and nothing fluctuates. WHY!!!!???
Old Aug 18, 2006 | 07:59 PM
Start from scratch. Do the MINIMUM amount of changes (like injector constants, and ALDL to 0, only, if you can), and just see if the problem goes away. Then if it's gone, start bringing in your other changes one area at a time, and see where it goes bad.
Old Aug 19, 2006 | 12:10 AM
Dirtbik3r's Avatar
I was already ahead of you there. I tried a stock bin with only the inj constants changed and had the same problem.
Old Aug 19, 2006 | 05:20 AM
I don't think it's this, is it?
; ERR # 43 Params
; >> KNOCK fail <<
LC234: .db 0x03 ; ?
LC235: .db 0xFA ; If KNOCK low time > 3.67 Sec,Enab ERR #43
; CALIB = Arg * 64
LC236: .db 0x01 ; ?
LC237: .db 0xB4 ; 90C, (194) MIN COOL TO ENABLE ERR 43
; CALIB = (Deg C + 40) * 256/192
LC238: .db 0xBE ; if LV LT this, disable ERR 43 test $BE = 190d
LC239: .db 0x47 ; Add 10 Deg Sprk Adv for #43 test
; CALIB = Deg * 256/45
LC23A: .db 0x2D ; If 02 Sensor >= 0.19v, then disable #44
; CALIB = Arg * 226
LC23B: .db 0x32 ; 20 Seconds to set #44
Let's see if this posted correctly
Old Aug 19, 2006 | 10:39 AM
Dirtbik3r's Avatar
That's very interesting...
90C = 194F - which is around where it goes crazy. So it's saying it purposely adds 10d of SA to test code 43 which is the ESC. So, wouldn't unchecking the ESC Diagnostic Enable(code #43) flag(In Tunerpro RT) act like a test to see if this is what is messing things up?
Old Aug 19, 2006 | 01:40 PM
Dirtbik3r's Avatar
Alright, I tried what i said and no luck. My problem happens right after 170F, not 190F. I start it up and timing is retarded about 10d. After about 130F, its kinda normal, and after 170, it's out of control.
Old Aug 19, 2006 | 07:02 PM
Use this XDF, see if the tables that you're looking at read the same. Also, don't use the 10k resistor. Also, use a timing light to see if it's really true. Also, try getting another bcc stock bin from moates, maybe AUJM.
File Type: zip
Old Aug 19, 2006 | 08:29 PM
Dirtbik3r's Avatar
Your the man! With the AUJM, it works great!!!! What car was the AUJM used in?
Old Feb 19, 2007 | 09:56 AM
Dirtbik3r's Avatar
I still cannot figure out where the extra timing is coming out of and I would really like to use my wideband hack with the apyp bin. Everey other bin or bin type works. I even tryed downloading the stock apyp bin and only changing the inj. constant and still I'm getting 10d SA. wtf?
Ghettobird52
Jul 5, 2024 11:18 PM
Terrell351
Jun 13, 2021 01:13 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
jharrison5
Aug 19, 2015 05:53 PM
