Actual SA Flaws?
Old Aug 1, 2006 | 05:27 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Actual SA Flaws?
I don't understand why my timing is so far off from my main SA Table.
Base Timing set at 6d BTDC
Base Timing in bin file set at 6d
PE spark dissabled
Lets say at 32LV8 and 800RPMS, the timing is 26d advanced in the main SA Table. The engine is at 190 degrees in Closed Loop. For that particular temperature in the spark correction table (Lv8 vs coolant), I have the value of zero entered.
So, sinced the lv8 vs coolant table is zero'd out and my base timing is set correctly, why is tunerpro displaying my timing as 8.79d advanced? Before I zero'd this table out, timing was less than 3d advanced!!!
BTW, this applied to all rpm's and loads. I just picked one for an example. Now, the last thing I did before noticing this was change the scale of the main SA table, I changed 4800RPMS to 4500 and added 5000, 5500, 6000, 6500, and 7000.
My current SA table. 6E Bin
Code:
	32	48	64	80	96	112	128	144	160	176	192	208
7000	37	40	42	41	38	36	35	33	30	28	28	27
6500	37	40	42	41	38	36	35	33	30	28	28	27
6000	37	40	42	41	38	36	35	33	31	30	29	28
5500	37	43	46	45	40.5	38.5	37.5	35.5	34	31.5	30.5	29.5
5500	38	44	46	45	40.5	38.5	37.5	35.5	34	31.5	30.5	29.5
4500	38	44	46	45	40.5	38.5	37.5	35.5	32	31	30	29
4000	38	44	45	43.5	40	38	37	36	33	31	30	29
3600	38	43	45	42	39.5	37.5	36.5	34.5	31.5	30	29	28
3200	38	43	43	41	38.5	36.5	35.5	34	31.5	29	28	27
2800	38	43	41	39	37	35.5	34.5	33	29.5	27	25.5	24.5
2400	37	40	40	38.5	36	34.5	33.5	32	27	24.5	22.5	21
2200	37	40	40	38	35	33.5	32.5	30	25	22.5	20.5	19
2000	37	40	39.5	36.5	33.5	31	30	27.5	22.5	20	18.5	17
1800	36	39	38.5	35.5	32	28.5	27	24	20	17.5	15.5	14
1600	35	38	37	34	30	27	25	21	17	15	13.5	12
1400	33	35	34	31	27.5	24.5	23	19	14.5	12	11	10
1200	31	33	32.5	30	26	23.5	21	15.5	11	9	8	7
1000	29	30.5	30.5	28	25.5	22	19.5	13.5	7	5	4	3
800	26	29	30	26	22	21	19	13	6	4	2	0
600	22	25	26	24	21	17	15	9	2	-1	-2	-2
400	18	21	22	21	19	15	12	6	2	2	2	2
Old Aug 1, 2006 | 07:23 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
How in the world did you add the extra RPM capacity to the tables? Simply forcing them in there won't do it.
Old Aug 1, 2006 | 07:54 PM
Dirtbik3r's Avatar
why?
I was reading this thread:
https://www.thirdgen.org/forums/diy-...hlight=maf+327
Old Aug 1, 2006 | 09:00 PM
Z69's Avatar
Z69
You can't just change your definition and edit....
The SA table scale change would be similar to a VE table change listed here- https://www.thirdgen.org/forums/diy-...ed-200rpm.html
With 200psi, you don't necessarily need 36*. Unless you have old style open chamber heads. In which case you need a bigger cam to lower your cyl. press.
Now, your problem may be due to your CTS table.
Not all xdf's factor in the bias value.
Typically it's the table value - the bias= the SA add/sub to the total SA.
Look at the calculation used by the xdf. If it's real simple and doesn't have two variables listed, it isn't showing the bias'd value.
When the bias is factored into the table display, you will typically see
+SA at lower temps, zero SA at normal temps, and - SA at higher (>220f) temps. Values on the order of 3-5 degrees in the table.
Old Aug 1, 2006 | 10:50 PM
You would have to modify the actual code to make that work. As far as I know, no one has done that to $6E yet.
Old Aug 2, 2006 | 11:42 AM
Z69's Avatar
Z69
???? I'm talking about the xdf displaying the CTS SA-the bias.
Old Aug 2, 2006 | 08:25 PM
I wasn't referring to your comment. I had replied very slowly, and you replied while I was typing, and was referring to the ability to just add the timing table rows into the xdf wasn't going to work, you'd have to modify the code to make the spark advance stuff actually work.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
bjpotter
Oct 4, 2015 07:48 PM
FormulasOnly
Oct 2, 2015 05:52 PM
