Tuner Pro vs TunerCat Constant names
Old Aug 16, 2006 | 10:28 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I was using Tuner Pro last night and I found something very disturbing.
I am using ver 4.0 and have not upgraded to 4.13, so these may have been changed. I also have TunerCat Which the constant names are not the same...
I used the same BIN for both of these.
Constant names:
TunerProRT - "Minimum RPM for highway spark mode" = 6350
TunerCat - "MAXIMUM RPH for highway spark mode" = 6350
TunerProRT - "Minimum speed MPH to enable Highway Fuel Mode" = 55 MPH
TunerCat - "Max Speed for Highway Fuel Mode" = 55 MPH
One is not correct, and I am not sure which. The Minimum RPM at 6350 seems awful high, and the Max speed at 55 mph seems low...
John
Old Aug 16, 2006 | 03:57 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Highway mode in the original code did not work properly without doing some rework to it.
Also I do believe the tables min/max were labled wrong way back when.(even the hack I think?)
Best bet to make it work is tie them together so u either have both or none.
later
Jeremy
Old Aug 17, 2006 | 08:15 AM
okfoz's Avatar
Jeremy,
THe problem is if I change the value in one program it changes in the other.
So if I change my TunerProRT - "Minimum RPM for highway spark mode" to 1800 then TunerCat will report "MAXIMUM RPH for highway spark mode" as 1800.
One thing that I think it may be is that the Definition that I was using in TUnerCat was 6eX and the definition in TunerPro is 6E... When I change TunerCat to 6EX then the values have the same name.
Does anyone know how to get better milage?
John
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
tmellott89
Oct 14, 2015 02:06 PM
ULTM8Z
Oct 2, 2015 01:25 PM
3.8TransAM
Sep 27, 2015 08:37 PM
