Trans vacuum sensor
Old Jun 12, 2001 | 07:45 AM
Aaron's 87's Avatar
Trans vacuum sensor
First off, I'll say I know little about trannies. I was reading through my service manual last night and the trans section said that there's a vacuum sensor that controls TCC lockup. Is this a MAP type vacuum sensor or just a solenoid (700-R4)? If it's a MAP type would some code changes allow a MAF car have a MAP? Just a crazy idea.
Old Jun 12, 2001 | 01:38 PM
gravitar's Avatar
You aren't talking about a vacuum modulator used to sense engine load and control shift points, are you?
If there's a vacuum "sensor" in the tranny itself, it is surely a switch and not an electrical transducer like the MAP sensor.
I guess I can't see why there would have to be a vacuum break in the TCC circuit, as it is controlled by the ECM anyway, which has full knowledge of the manifold vacuum!
Old Jun 12, 2001 | 02:01 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by Aaron's 87:
First off, I'll say I know little about trannies. I was reading through my service manual last night and the trans section said that there's a vacuum sensor that controls TCC lockup. Is this a MAP type vacuum sensor or just a solenoid (700-R4)? If it's a MAP type would some code changes allow a MAF car have a MAP? Just a crazy idea.</font>
Chiilton, or Haynes?.
Whichever, it's dead wrong, as far as efi cars. They use % TPS and vehicle speed sensor(and gear / brake switches) (with a coolant temp enable).
Old Jun 12, 2001 | 02:55 PM
Desert86Roc's Avatar
The "sensor" you are talking about is not a sensor. There is a combo TCC power switch / Cruise Control vacuum release switch that activates when you push on your brake pedal. This interrupts the power to the TCC solenoid, and "turns it off" while braking, and also releases the vacuum that keeps your cruise control "on". As soon as the brakes are released, the power to the purple wire (solenoid positive) is restored.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] My 86 IROC 305 TPI Page (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.362 @ 88.238 mph (uncorrected, headers, no NOS)
&lt;&gt;&lt;
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
perZ
Aug 21, 2015 05:51 PM
mdtoren
Aug 16, 2015 05:45 PM
