Is any one out there running a 400(or larger)tpi with MAF with 30lb injectors....
perferrably with the long tube setup...
looking for someone to talk to that's got the similiar setup.
86 IROC 406 tpi mass air
trickflow g2 heads
slp runners
stock tpi
about a 272 custom hyd roller comp cam
30 lb injectors
no smog,a/c,or egr
working on homemade chip
ARAP as a base setting
running on radials....
Check out my new website!
http://jackel_38610.tripod.com/wildstreetracing/
trickflow g2 heads
slp runners
stock tpi
30 lb injectors
no smog,a/c,or egr
That was me... I'm in the middle of switching to SD.
408cid 1985 Corvette
http://www.mojosgarage.com
I ran a 400 with ASM siamesed long tube before switching to a Superram and then rebuilt the motor and went to the Miniram. What do you want to know?
N/A 406, TPIS Miniram, 58mm TB, 30lbs injectors, Custom Ground Elgin Cam, Ported TFS heads, SLP 1-3/4", & DFI computer.
11.70@117mph
11.70@117mph
<font face="Verdana, Arial" size="2">Originally posted by FAST LiFE:
</font>
</font>
never mind I see your dfi in signature.
I've been wanting to compare my massair tables and pe vs rpm tables
[This message has been edited by Z-BOSS (edited June 12, 2001).]
At the time, the DFI was not used. I used the stock 88' MAF computer with a prom burned for me from ASM. Sorry for not clarifying this.
11.70@117mph
11.70@117mph
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
